Old 03-24-2007, 04:35 PM
GTwannabe's Avatar
GTwannabe GTwannabe is offline
Duplicate SD/HD recordings
I recently added an HDHomeRun to my SageTV setup. It works properly, but Sage is doing something strange.
I have certain favorites limited to only record on the HD stations. The problem is that if that favorite is simulcast in HD and SD (Tonight Show, Motorweek, etc), Sage records both at the same time.
Any ideas?
Intel NUC SageTV 7 server - HDHomeRun PRIME - 2TB iSCSI ReadyNAS storage
Intel i3 HTPC SageTV 7 Client - Win 7 x64 - Onkyo TX-674
Old 03-24-2007, 06:14 PM
flavius flavius is offline
Do you have Intelligent Recordings enabled? I'm seeing quite a bit of that as well, not for all shows, though. I have always attributed this to a lack of smart in the IR engine...
Old 03-25-2007, 01:26 AM
carlgar carlgar is offline
I believe this problem only occurs if the favorite has a non-unique show Id like SH329370000. This is usually news type shows. Sage cannot tell that they are the same show. I got around the issue by limiting those show to only the channel I want to record on.
Intelligent recordings will also cause duplicate recordings but it should not be a problem because it only records when a tuner is available.
Old 03-25-2007, 09:34 AM
Not sure I understand why you think that duplicate recordings are not a problem.
Old 03-25-2007, 10:06 AM
I don't consider them to be a problem (under normal conditions) because they only record when a tuner is available and they are the first to be deleted. Why do you think they are a problem?
Abnormal conditions: Currently I have encoutered 3 bad .ts files generated by the homerun. 2 of them were intelligent recordings and 1 was a favorite. These recordings present a major issue for Sage, it will cause Sage to hang, This is a major issue if using the server when you encounter the hang. I now only encounter this hang using the client or the extender, so I can just restart to get around the proglem.
Old 04-21-2008, 08:01 AM
davephan's Avatar
davephan davephan is offline
Recently, I added a HDHomerun unit for over the air HD broadcasts. I do not have a HD television yet and what the content with a MVP. I am getting duplicate recordings on some programs of the SD and HD content.
The problem is that some of the HD channels have black borders on the top/bottom and left/right, instead of only the top/bottom. This makes the resulting image pretty small on my television screen.
I removed a couple of the HDHomerun local channels from the PVR-350 tuner that do not have left/right and top/bottom cropping. Those two channels are only received by the HDHomerun, and no longer have duplicate recordings.
I would like to record those channels that are cropped on all four sides or on top/bottom with the PVR-350, unless there is a conflict. If there is a conflict, then use the HDHomerun tuner to record those channels.
Does anyone know if there is a solution yet to the SD and HD duplicate recordings problem?
Dave
Extenders: 1-HD-300, 2-HD-200
STV Import: Imdb Search Interface (7 Jul 2008 v6.10) nielm SageTV Customizations 431 01-28-2011 04:38 PM
Duplicate recordings error - have you see it too? stevech SageTV Software 0 11-14-2006 09:44 PM
Duplicate recordings issue Gaurav SageTV Software 3 09-09-2006 08:02 PM
Duplicate recordings because of EPG data teknubic SageTV EPG Service 2 04-17-2006 08:39 AM
Duplicate Recordings rsagetv99 SageTV EPG Service 3 02-24-2006 04:41 PM
