Old 12-28-2018, 10:25 PM
Duplicate metadata!?!?!
I had to use an old backup wiz.bin after having some corruption on wiz.bin. So, I'm editing orphaned videos and get finished with them and find that I have 20 or more videos with the exact same (wrong) metadata. Every time I edit one of these videos, they all change to the new metadata!
ASRock B450M Pro4 AM4 mATX AMD Motherboard, AMD Ryzen 5 2600 3.4GHz, Crucial Ballistix Sport LT 16GB (2 x 8GB) DDR4-3200, EVGA GT 1030SC, WD - Black SN750 NVMe SSD 250GB, 1x WD80EFAX 8TB, 2x WDBH2D0040HNC 4TB, USB-UIRT, Colossus 2, WinTV-quadHD USB, Windows 10 64bit
Old 12-29-2018, 05:18 AM
I've seen this from time to time with sagetv. The only way that I've been able to fix it, is copy the file to another location, then tell sagetv to scan for media (so that sagetv recognizes they are deleted), then copy them back, and then tell sagetv to scan again.
Old 12-29-2018, 10:43 AM
Thanks. I've had this happen on 1 or 2 files before, not 63 like this time. This sounds doable.
Old 01-02-2019, 01:38 PM
Perils of moving Videos to Programs and editing metadata.
change metadata not visible from Raw Metadata JonTom Batch Metadata Tools 2 08-30-2011 03:53 PM
Duplicate Movies Emsdad Sage My Movies 4 10-30-2010 05:08 PM
Clean out old metadata created by My Movies before creating new metadata for SageTV? Texas-Hansen SageTV Customizations 0 02-12-2009 10:31 AM
Duplicate recordings Ken C SageTV Software 15 01-13-2009 12:24 AM
Duplicate SD/HD recordings GTwannabe SageTV Software 5 04-21-2008 08:01 AM
