Old 07-21-2005, 08:26 AM
modurn modurn is offline
Problem getting the sage client connected to the sage server
Ok I am running Sage 2.2 the full version on one of the PC's on my network. I went into the advanced settings and made sure that the server function was enabled. I installed the 2.2 client on another machine on my network, when I try and connect to the server (ip: 192.168.1.101) it times out and says it cannot connect. I was running firewalls on both systems but I turned both firewalls off to see if that was the cause, same result. I am using a Linksys router as both hub and router. Both systems are able to ping each other fine and both systems are able to reach the internet with no problems. Anyone able to give me any help?
Old 07-21-2005, 10:37 AM
The three things I can think of to check for client/server connections are:
  1. they need to be the same version (looks like it is covered)
  2. the ports listed in this FAQ need to be open (also looks covered, but might want to double-check)
  3. the same client license key cannot be used on another PC.
If #3 is or was the case, then shut down the other client & restart SageTV (server).
If you continue to have problems connecting, don't forget to see what SageTV tech support has to say.
