Old 01-16-2007, 09:58 PM
shawn shawn is offline
No volume control - keyboard or Hauppauge remote
I'm running a new install of Sage 6.0 on a clean install of Win2K SP4 with an Asus A8N-VM CSM with: integrated Nvidea graphics and HD audio. The audio has digital out, but I am using the line out plugged into the audio in on my Philips plasma TV. My capture card is a Hauppauge WinTV PVR-150 with the 45 button remote.
My remote works flawlessly with Sage EXCEPT for volume control. The volume buttons are mapped to keyboard controls CTRL-R AND CTRL-ALT-R for up and .....E for down. When I press Vol. up or down, the volume bar shows up but does not change. It appears as if the volume is all the way down, but I have sound and I can control the volume via the TV. The keyboard controls CTRL-R AND CTRL-ALT-R and ...E and CTRL-RIGHT and LEFT do not control the volume either. I can't even move the volume slider with the mouse.
Again, I do not have any digital audio cables connected to my TV: this is analog volume that I am not able to control. This is driving me crazy. I have searched the threads and found similar problems, but nothing exactly like this. I have Sage set to use the Default Wave Out, not HD audio or direct sound, but neither of those work either.
ANY help here would be greatly appreciated!
Old 01-16-2007, 10:18 PM
chughes's Avatar
chughes chughes is offline
Pretty sure Sage will only adjust wave volume, and not system volume - or maybe it's the other way around. I think this issue goes away if you put your sound out to an amplifier. Otherwise, I think I heard of a volume tool that will force your system volume to mimic your wave volume. Let's see... where is it...
Oh, here it is.
Hope that helps.
AMD A8-3850 | 4 GB RAM | 80GB SSD + 1TBHDD | Pioneer DVR-110D | Silverstone LC16M-S w/ Harmony 890 remote
Hauppauge HVR-2250 | USB-UIRT
Win 7 | SageTV 7 | nVidia decoders
Yamaha HTR-5920 | Energy Take 5.1 | Samsung LN32D450 via HDMI | Winegard Square Shooter
Old 01-17-2007, 08:50 AM
I'll try this when I get home and see what happens. Thanks for your help.
Old 01-18-2007, 10:36 PM
No luck
This didn't work. My master was: Recording Control. On my other computer it was: Master Volume. I'm lost here.
