Old 03-26-2008, 01:28 PM
cmf cmf is offline
Volume up / down troubles with my remote control
Dear Sagies,
I am using a Streamzap - zapper with SCONI - software to assign the commands to the related key - commands.
I assigned VOLUME-UP to "CRTL-RIGHT" and VOLUME-DOWN to "CTRL-LEFT".
Using this setting it works perfectly in TV and MOVIE but the function is wrong when playing MUSIC files or watching ONLINE VIDEOS. IN this modules it seems that CTRL-RIGHT / LEFT is not used for Volume control, is it?
Now my question: Am I right and when yes, how to assign the right keys which work in all modules? I was coming over from MEDIAPORTAL. There I could assign individual RC - setting / window but in SAGE I only see SAGE-Client as running window...
Hope that somebody could help to sort out that problem.
thanks, Christian
br, Christian
SERVER: OS: VISTA, 1,86MHZ Dual CORE, 2GB RAM, 1 x 500GB, 1 x 1000GB HDD, 3 x FIRETV DVB-C
CLIENT I: OS: VISTA, 1,86MHZ Dual CORE, 2GB RAM, 1 x 250GB HDD, ATI 2600HD
CLIENT II: STX-HD100
SAGE 6.5 & SAGE-MC, Stephan´s network-encoders as virtual tuner-cards
Old 03-26-2008, 02:06 PM
Ctrl + Right/Left are assigned to the Right/Vol Up and Left/Vol Down commands by default.
You could either reassign those keystrokes to the Vol Up/Down commands, or simply use the keystrokes that are already assigned to those commands.
The end of chapter 5 in the PDF manual lists all the commands and their default keystrokes, or just check out Detailed Setup -> Commands -> Link Keystroke screen.
does it recognize the hauppage remote control? gveres SageTV Mac Edition 3 03-26-2008 11:28 PM
Remote Control issue with 6.2.4 pilotguy7ca Hardware Support 5 07-09-2007 12:56 PM
No volume control - keyboard or Hauppauge remote shawn Hardware Support 3 01-18-2007 10:36 PM
SPDIF and volume control jbarr Hardware Support 1 10-05-2006 08:34 AM
Do i have my remote control options understood orangezero Hardware Support 6 05-05-2006 10:32 PM
