Old 11-23-2008, 12:58 PM
rdefino rdefino is offline
Recordings not showing up after copying sage directory to new build.
I setup another OS/Sage build on another drive. I backed up the sagetv directory from the original system. Sage works fine on that system. So made sure the service was shut down and that sage wasn't running. I copied the enterire direcotyr to a back directory.
Installed my new driver. It's already built. I installed the same ver sage that is on the other drive. Made sure sage wasn't running and copy the backed up dage onto this version.
Starterd up sage and nothing under recording. If I look in the videos directory it sees every recording and rip dvd. I setup is there from the other build. Just not sure why I can't see the recording, favorites, schelde recording.
The wiz.bin file is the same one from the other build. They match up fine.
I'm running Vista 64 bit.
Any thoughts.
SageTv server: 2008 64 BIT R2, Asus MN2-E, AMD dual core 4200, 4gb ram, Promise raid 5 8TB, 80gb Sata boot drive w/OS, 2/ dual tuner HDhomeruns, HD-PVR
3/HD-100's, 1/HD-200
Old 11-23-2008, 01:07 PM
Figured out what it was. On 64 bit there is a program files and program file
x86. Pieces of sage get put in both. Need to copy the wiz.bin to the program files directory.
Old 11-23-2008, 05:37 PM
On a 64 bit OS your main folder for SageTV should be Program Files (x86). That's where all the 32 bit programs go by default. Your wiz.bin and all of your Sage files would go there. That is where the install puts them by default. The Program Files directory is used for native 64 bit programs.
My Sage TV 6.3 Problems and Fixes (Long) tcsubwoofer SageTV Software 12 05-08-2008 07:35 PM
Sage fogets about series recordings at xmltv import Madcoder SageTV EPG Service 2 04-07-2006 03:46 PM
Sage Recordings items refresh jchiso SageTV Software 2 02-14-2006 01:16 PM
STV: Cayars17 Ultimate STV (Release 17 - Jan 18) Cayars SageTV Customizations 3664 12-13-2005 05:35 PM
