I am having a problem with Sage Client.
It discovers servers and after you select an active server, it just sits there and says "SageTV Connection is Initializing." After a new window pops up with "An exception occured in Java: java.lang.NullPointerException" My other PC with Client works just fine. I have uninstalled/reinstalled java and Sage to no avail. I also searched the forum and the only thing I found was a LONG time ago about a STV being corrput. So, not only did I reinstall SageClient (as described above) but after that didn't work I also copied the STV that works fine on my Server to the client and it still did not work. I am running server in service mode, but I doubt that makes any difference becuase another PC's client works. I turned loggin on and here is what comes back: Code:
Wed 7/5 8:48:48.842 user.dir2=C:\Program Files\SageTV\SageTV Wed 7/5 8:48:48.845 classpath=C:\Program Files\SageTV\SageTV\Sage.jar;C:\Program Files\SageTV\SageTV\plugin.jar;C:\Program Files\SageTV\SageTV\;;JARs\commons-jxpath-1.1.jar;JARs\commons-logging-api.jar;JARs\commons-logging.jar;JARs\jcifs-1.1.6.jar;JARs\jdic.jar;JARs\mx4j-impl.jar;JARs\mx4j-jmx.jar;JARs\mx4j-remote.jar;JARs\mx4j-tools.jar;JARs\sbbi-jmx-1.0.jar;JARs\sbbi-upnplib-1.0.3.jar Wed 7/5 8:48:48.845 JVM version=1.5.0_07 Wed 7/5 8:48:48.845 OS=Windows XP 5.1 Wed 7/5 8:48:48.847 Succesfully setup system shell hook Wed 7/5 8:48:48.848 not specifiy WinkeyboardHook in registery, load default one Wed 7/5 8:48:49.284 ImageUtils loading URL jar:file:/C:/Program%20Files/SageTV/SageTV/Sage.jar!/images/splashclient.gif Wed 7/5 8:48:49.356 ImageUtils creating BI copy sun.awt.image.ToolkitImage@18ac738 Wed 7/5 8:48:49.919 SageTV V5.0.4.92 Wed 7/5 8:48:50.098 hostname=kitchen Wed 7/5 8:48:50.179 Sending out discovery packets to find SageTV Servers... Wed 7/5 8:48:50.364 Discovery packet received:java.net.DatagramPacket@c51355 Wed 7/5 8:48:50.365 Added server info:mediaserver,V5.0.4,192.168.1.105 Wed 7/5 8:48:55.321 Error discovering servers:java.net.SocketTimeoutException: Receive timed out Wed 7/5 8:49:36.498 ImageUtils loading URL jar:file:/C:/Program%20Files/SageTV/SageTV/Sage.jar!/images/tvicon.gif Wed 7/5 8:49:36.501 ImageUtils creating BI copy sun.awt.image.ToolkitImage@7c6768 Wed 7/5 8:49:36.920 ImageUtils loading URL jar:file:/C:/Program%20Files/SageTV/SageTV/Sage.jar!/images/tvicon_anim0.gif Wed 7/5 8:49:36.922 ImageUtils creating BI copy sun.awt.image.ToolkitImage@a981ca Wed 7/5 8:49:36.923 ImageUtils loading URL jar:file:/C:/Program%20Files/SageTV/SageTV/Sage.jar!/images/tvicon_anim1.gif Wed 7/5 8:49:36.925 ImageUtils creating BI copy sun.awt.image.ToolkitImage@1a1c887 Wed 7/5 8:49:36.926 ImageUtils loading URL jar:file:/C:/Program%20Files/SageTV/SageTV/Sage.jar!/images/tvicon_anim2.gif Wed 7/5 8:49:36.928 ImageUtils creating BI copy sun.awt.image.ToolkitImage@167d940 Wed 7/5 8:49:36.929 ImageUtils loading URL jar:file:/C:/Program%20Files/SageTV/SageTV/Sage.jar!/images/tvicon_anim3.gif Wed 7/5 8:49:36.931 ImageUtils creating BI copy sun.awt.image.ToolkitImage@7ffe01 Wed 7/5 8:49:37.094 Wizard starting to load database info... Wed 7/5 8:49:37.108 Wizard DONE loading database info. loadTime=0.0010 sec Wed 7/5 8:49:37.347 SageTV received connection from:Socket[addr=/192.168.1.105,port=42024,localport=1878] Wed 7/5 8:49:38.535 Connection lost from: Socket[addr=/192.168.1.105,port=42024,localport=1878] by:java.io.EOFException Wed 7/5 8:49:38.536 Cleaning up c/s connection Wed 7/5 8:49:38.551 MAIN THREW AN EXCEPTION: java.lang.NullPointerException java.lang.NullPointerException Wed 7/5 8:49:38.553 at sage.bp.do(Unknown Source) Wed 7/5 8:49:38.553 at sage.bp.for(Unknown Source) Wed 7/5 8:49:38.553 at sage.SageTV.<init>(Unknown Source) Wed 7/5 8:49:38.553 at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) Wed 7/5 8:49:38.554 at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source) Wed 7/5 8:49:38.554 at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source) Wed 7/5 8:49:38.554 at java.lang.reflect.Constructor.newInstance(Unknown Source) Wed 7/5 8:49:38.554 at java.lang.Class.newInstance0(Unknown Source) Wed 7/5 8:49:38.554 at java.lang.Class.newInstance(Unknown Source) Wed 7/5 8:49:38.555 at sage.Sage.void(Unknown Source) Wed 7/5 8:49:38.555 at sage.Sage.b(Unknown Source) Thanks! Stacy |
Client connection problem here too!
I have Sage Client on 2 Windows PCs, both fail to connect while reporting "An Exception occured in Java: java.lang.NullPointerException". I have the latest Sage WHS server beta running on RC1 of WHS, but had the same problem using the current v6 Sage for Windows.
Can anyone help, please? This is a very promising setup, but about as useful as an ashtray on a motorbike at present. John |
For both the above posts I would reexamine your firewall and make sure the correct ports are still open.
Stacy-yours is timing out on the discovery. John-WHS is based on Server 2003 and inherently more secure. You may want to disable it entirely on server and clients and back your way back into it. Gerry
It appears that I have the same issue running the SageTV Client 6.5.13 under my vmware development environment (windows xp)
I recently updgraded my server from 6.4.8 to the latest 6.5.13. Everything else connects fine (hd extender, placeshifters, mvp), but now my windows xp dev client (vmware) just sits there at "SageTV Connection is initializing"... and eventually it will time out with a NullPointerException. Any suggestions?
Well.... I really don't think this is a SageTV issue, since i rolled back my sagetv server and resinstalled the sagetv client under windows to 6.4.8 and the windows client still sits there. So it must be something to do with my vmware windows....
Just for reference.. Sage Suppport had me reactivate my license, and now my client can connect, and I no longer get the NullPointerException.
My problem was (i suspect) that I upgraded my server hardware, and as a result, my license was invalid, although sage server never complained.
