I just missed an episode of Rock Star: Supernova (my wife's going to kill me!) because the episode information incorrectly listed it as "Watched." I've had this problem on this show before - they have a performance show and a results show each week, and every week the performance show is listed as "Watched" before it airs, presumably because the performance shows all share the same information. I have to remember to clear the Watched status every week or it won't record. My question is, is there a way I can setup the series so that it will record even when an episode has been "watched." For instance, on Tivo I believe there were settings for First Run, re-runs, or "All episodes" which would record every episode regardless of whether it had been recorded before. Have I missed the way to do that in Sage??
If your listings are showing non-unique IDs (SH#), then you could try setting the option to force SageTV to treat non-unique IDs as different shows instead of trying to determine if they are the same episode. The option is in the default STV & it uses the epg/advanced_show_redundancy_check property. You would want to set it to false, and it should be set in sage.properties AND sageclient.properties if using a client or service mode. Quote:
I'm hoping there's something else I can do besides making manual recordings or re-setting the watched status every week, because that sort of takes away the "set it and forget it" advantages. Is there no way to just tell Sage to "record all" regardless of whether that episode has been recorded? (I'm assuming here that for upcoming shows, Sage automatically sets it to "watched" if that showID has been previously recorded... Is that how it works, or does Sage only set an upcoming show to watched if that showID has been recorded AND actually watched?) The only downside to having the ability to tell Sage to record every episode regardless of watched status is that it would record things you've already seen, right? |
(I moved this to a new thread, since it didn't really have anything to do with SageMC.)
Hmm... Looks like it is indeed an EP (episode ID). So Sage thinks that there are unique IDs for each episode, but in fact many of the shows are using the same episode ID (EP). (fwiw, there are some other shows I've noticed this on too, just not any that I have set for series recordings - such as Access Hollywood, which for me has the same exact showID (EP) for every single episode.)
Could this have anything to do with the fact that I'm using an XML guide data loader (Stephanie's)? All of my data is coming from zap2it. Those questions aside, I'm still unsure why Sage wouldn't provide the opportunity for a "record all" type series setting, given that it's obviously possible for even EP showIDs to be wrong at times. For instance, there's apparently no way for me to set up a series recording for Access Hollywood if I wanted to because every showID (EP) is the same, so since I've watched a single episode before, every episode in the upcoming schedule is already set to "Watched." Is this a limitation of the base Sage API, or is this something that I could try to customize my STV to work around? Would it be possible for me to create a "record all, regardless of showID" option for myself? Thanks! |
Do you need to use XML? I don't know where you are located, but the built in EPG data covers the US and Canada. Quote:
SageTV is designed to intelligently know what it has recorded, what has been watched, etc. If bad/incomplete data is put into that system, it can't do what it should be able to do. Quote:
Additionally, I liked the option to be able to rename my channels so I could have it say "ABC" for instance instead of "KABC-DT." There were a few other smaller issues that using XML also provided benefits when I started using it that are not as big a deal now because of the FCL plugin... But primarily, I just hated seeing over half my channels say "No Data" all the time. |
