Old 03-24-2007, 03:31 PM
farfromuman farfromuman is offline
MP4 files lockup Sage
Using the last 3 RCs I am unable to play any Divx or Xvid files. I tried various decoders with the same effect, on play first frame displays and audio plays - pressing stop freezes the system and with FSE the only way to recover it to power cycle the PC. The workaround I found is to use SageMC and from the stop menu restart the file, then it plays fine. I reported the bug 2 times but I have not received a response. I am wondering if anyone else is having the same problem.
Server: Sage 9; 8TB, i5 4690k 16GB DDR3 2XHDHR3, Windows 10 PRO 64BIT
Client 1: HD300; Panasonic TC-P65S64;
Client 2: HD300; Samsung 46" LCD;
Client 3: HD300; 60" LCD;
Old 03-25-2007, 12:52 PM
parkimar parkimar is offline
Hi,
can you play the .avi / .mp4 files using any other program ?
If it works in windows media player, you can try adding always_use_dshow_player = true to your sage properties file.
Cheers
Mark
Luckily Computers Repair Themselves
Old 03-25-2007, 01:42 PM
I tried always_use_dshow_player=true setting with no change. Avi and MP4 play fine in WMP11 and Sage will play them if I restart the file otherwise it hangs on the first frame. The only way to make Sage play nice is to switch from VMR9 to Overlay.
Mariusz
Old 03-25-2007, 05:43 PM
Actually I just went through my files and your in better shape than me.
I can play .avi's encoded with Xvid, but .mp4 won't play at all.
They play fine in everything else (WMplayer, Zoom , etc).
I have always_use_dshow_player = true but sage seems to ignore it.
Oh well, I rarely encode stuff nowadays anyway, guess I'll just have go into the loft and pull out the originals and throw DVDfabdecrypter at them.
Cheers
Mark
Corrupt video files in Sage kpsmith SageTV Software 3 03-13-2007 02:03 PM
Missing files after Sage move ptaylor SageTV Software 10 02-15-2007 04:50 PM
getting sage to play a playlist xlr8shun SageTV Software 4 05-19-2006 12:53 PM
Sage will not play/find mpeg-2 files. mephiston5 SageTV Software 2 01-14-2006 06:17 AM
