MP3 Playback has artifacts
Whenever I play MP3s using Sage I get what sounds like knocking sounds. This happens to almost all my MP3s. Using winamp and WMP11 the files sound fine on the same PC. Does Sage use built-in decoder for MP3 playback?
Thanks, Mariusz
Server: Sage 9; 8TB, i5 4690k 16GB DDR3 2XHDHR3, Windows 10 PRO 64BIT Client 1: HD300; Panasonic TC-P65S64; Client 2: HD300; Samsung 46" LCD; Client 3: HD300; 60" LCD; |
I get the same thing. It sounds like improper decoding. It's very tinny and the pops sound like someone banging on a tambourine without the bangles. Playback in WMP11 or anything else is fine.
Server: WinXPProSP2, Athlon64 4000+ Dual Core, ASUS NVidia Premium SLI MB, 2Gig DDR, 2xGeForce 7800GTX in SLI, 2x250G SATA HD's in RAID stripe, 250G SATA Video, 250G Backup HD, Onboard Realtek sound, PureVid 1.0.2.223, SageTV 6.3.8 HTPC: WinXPProSP2, AthlonXP 1700+, 1GigDDR, ATI Radeon 2400HD AGP with , Overlay, SageTV 6.3.8 iTreadmill: Media MVP with USRobotics wireless bridge. |
I get the exact same thing. I am trying to figure out what SAGETV is using to decode the mp3 to figure if I have bad codecs, but I I am not sure the best approach.
Anyone else with this problem find an answer? My MUSIC folder is on a DRIVE connected via USB 2.0. Maybe that has something to do with it? It does not happen for all music...
Eckwell / Chicago, IL SERVER: AMD Phenom III 8750 Black / 4 GB / XP Pro / JV1.6.24 / V7 / 2 PVR-HD (DirectTV) & HDHR (2xATSC) STORAGE: WD Raptor36GB boot / 11TB in 2 eSATA enclosure DEFAULT STV Comskip triggered by DirMON2 --- HD100 / HD200 /HD300 BMI fanart |
My fix is to run ffdshow and make it decode MP3
Do you mean that you install ffdshow and then have Sage use it when decoding MP3s, or do you mean that you open ffdshow and play mp3s from there?
if the former, can you walk me through how you set that up? Thanks
After you install ffdshow, go to the audio decoders and make it the default for MP3. Sage will start using ffdshow for mp3s. I am away from home for a week so I can't look it up for exact steps.
Setting Default audio decoder?!?
You don't need to, just open FFDShow audio options and tell it to decode MP3s, then Sage will use that default decoder.
unRAID Server: Intel Core i5 7600K, 48GB DDR4, 2x512GB PCIe M.2 Cache Pool, 2x10TB SATA3 Parity Drive, 3x8TB SATA Array, 1x hdHomeRun DVB-T2 Quattro, IPTV via xTeVe, unRAID 6.8.3, tvHeadEnd for recording back end, Emby Clients: 3 Nvidia Shields, 3 FireTV, 3 Win10 Pro PC Clients |
thank you.
Placeshifter MP3 playback quality issue | boomxr | SageTV Placeshifter | 3 | 03-29-2007 10:27 PM |
MP3 playback cut short | GuitarManDave | SageTV Media Extender | 3 | 06-07-2006 08:09 AM |
mp3 playback through mvp | pbennington | SageTV Beta Test Software | 4 | 04-17-2006 10:22 AM |
Sage 4.0 mp3 playback Stutter | vfrancis | SageTV Software | 1 | 11-28-2005 07:07 PM |
