HVR-950Q causes BSOD
I really like this tuner, it picks up the most digital stations out of all my HD tuners but it causes BSOD when I preview in channel setup after a min or two (scanning works fine) also when trying to record or watch it does not actually record anything. I am using the latest drivers in Vista (ver 1.85.26190). Initially it worked fine and only last night I noticed this behavior.
Thanks for any ideas. Mariusz
Server: Sage 9; 8TB, i5 4690k 16GB DDR3 2XHDHR3, Windows 10 PRO 64BIT Client 1: HD300; Panasonic TC-P65S64; Client 2: HD300; Samsung 46" LCD; Client 3: HD300; 60" LCD; |
My 950Q sometimes de-initializes
From time to time - & it seems to be getting more frequent, my 950Q has trouble recording. Symptoms: attempts are made, but all I get is several 0-byte files. It also gets quite warm. I can fix it by rebooting or disconnecting & reconnecting the device, but since the dropouts are unpredictable, it's causing me to lose recordings. Today, we had some thunderstorms in the afternoon, so powered down the pc for a few hours. On power-up I even made sure signal was being recognized by checking the tuner setup. At 6:30pm or so it was fine. At 8pm, when it was supposed to record, nothing. The fixes work by reinitializing the stick; is there any way to get Sage to force a reinit, or should I take this up with Hauppauge as a hardware problem?
Server: Windows 8.1 4gb RAM; 4TB SATA + others. Homebrew quad core AMD. Inputs: Haup. 980, 850 & 950Q on ATSC; Haup 1600 on ATSC & Comcast 2 DTAs with USBUIRT for NTSC. Haup 1800 on ATSC. HDHR Dual (ATSC). Sage 9.22 64 bit. |
HVR 1600 - good enough or should I consider alternatives? | wolverines | Hardware Support | 30 | 01-24-2009 09:17 PM |
HAUPPAUGE hvr 1600 playback choppy | dc9mm | Hardware Support | 4 | 12-15-2008 10:46 AM |
Hauppage HD PVR BSOD on IR Blaster Config | bastian74 | Hardware Support | 1 | 10-15-2008 01:28 PM |
New WinTV HVR 1600 Causes PC to Fail to Boot | Steverino | Hardware Support | 2 | 06-06-2008 10:29 AM |
HVR 1600 - QAM Issue with Local HD | subhadipsas | Hardware Support | 2 | 04-16-2008 08:14 AM |
