Old 06-23-2009, 12:24 PM
matterofrecord matterofrecord is offline
What is the best way of recording the news everyday
Hi
I'm wanting to record the news every day but if I setup the news as a favourite program it only records once or twice ( presumably because the epg data is always the same and sage doesn't record duplicates ). Is there any way of recording programs that are always different yet always have the same epg data. I know I could set a timed recording but I was hoping for a more elegant and simple way of recording these programs.
Any ideas or should this be on the sage wish list??
J
Old 06-23-2009, 01:51 PM
QueOnda's Avatar
QueOnda QueOnda is offline
I record the news everyday. I have it setup as a favorite to record 1st runs and re-runs on the specific channel I want. Works like a champ. Records the news every night for me.
Server: HP AMD64 dual core running Win7 64bit (MCE disabled) with 4G memory Tuners: 2 PVR-500(disabled), 3 HDHR and 1 HDPVR Clients: 2 HD200 and 1 HD100 TV: 70" and 52" and 42" Media Storage: ReadyNas 8TB Recording media: 300GB + 200GB+ 250 GB Network: Gigabit backbone'
Thanks to all the developers who work on SageMC, code, utilities and plug-ins to make SageTV better!!!
Old 06-24-2009, 08:32 AM
freedml freedml is offline
I record the NewsHour and it annoyingly records it 3 times a day. How are you recording the 'news' now (Favorite by title, keyword, ???)?
Old 06-25-2009, 05:55 AM
SWKerr SWKerr is offline
You can set it to record at a select time and on a specific channel in the advanced settings. I also limit mine to a max of two recordings so that it will record over the older episodes automatically. (Set to keep until space is need or it will simply stop recording new ones.)
Old 06-25-2009, 06:05 AM
This is really dependant on how the guide data is representing your indiviudal newscast. The two news programs I have set as favorites DO have unique guide data each day (not in description, but in ID, which is what matters), so i just get one recording a day. Like I said, it's a limitation of the guide data, not a problem with news programs in general.
Old 06-25-2009, 04:17 PM
mtenboer mtenboer is offline
I record a network news station each morning without a problem - It is set up as a favorite and I guess it has a unique identifier.
However, I would really like the Favorite set up menu to allow me to save only the most recent recording and automatically overwrite the oldest. Currently if you set a maximum number of recordings to 2, then once it reaches that level it stops recording. I would like a checkbox that says "Continuously replace oldest" so that I always have the most recent show and Sage overwrites the oldest one.
Old 06-25-2009, 05:25 PM
Sage SHOULD keep the newest, (2 in your case) and overwrite the oldest. if this is not occurring, it is because it feels you've already recorded the new one, so it doesn't need to. this comes down to the unique id thing again.
Old 06-26-2009, 05:36 AM
wrems's Avatar
wrems wrems is offline
I see your point… At the same time, I record news shows and have never been bothered with manually deleting the older files I do make sure that I only record 1 specific airing of the news to avoid recording multiple airings throughout the day. I know in SageMC there is an airing time constraint in the series settings, as well as a channel constraint. I don’t recall if these are options in the regular Sage STV or not…
Old 06-26-2009, 05:58 AM
Just realized that if you are recording up to your Max Keep number, and it is not recording any more, it's probably due to you having AutoDelete turned off for that favorite.
Also, yes, I do believe the default STV has favorite time restraints.. I think It's under advanced options for the favorite, or something like that.
Old 06-26-2009, 08:28 AM
This is available in Sage now ... just simply set your favorite to do this.
Just set your fav to keep at most the number you want and set autodelete to yes.
Old 06-26-2009, 06:19 PM
Thanks everyone. I did not know about the autodelete feature.
how do i set a program to record everyday? placez SageTV Recorder Software 1 10-05-2007 07:13 PM
I.R. is awesome but stop recording the damn news!!! kregory SageTV Software 5 05-04-2005 01:34 PM
SageTV In The News dkardatzke Announcements 0 04-13-2005 03:27 PM
Any News on Studio? Watter SageTV Beta Test Software 4 11-24-2004 11:29 AM
Any news on Studio? mikejaner SageTV Beta Test Software 9 06-05-2004 05:41 PM
