Old 05-31-2010, 03:02 AM
Signal Strength plugin not working
I installed the signal strength plugin and I'm not seeing the signal strength in the OSD. The plugin is enabled and I can't find a config entry off the plugin display or setup/detailed/configuration (or support thread).
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 05-31-2010, 04:40 AM
tmiranda's Avatar
tmiranda tmiranda is offline
If you are talking about this: http://forums.sagetv.com/forums/show...&highlight=OSD
I have not ported it to Sage7. It is on my list of "to do's".
Old 05-31-2010, 05:15 AM
It's listed as a plugin in V7's plugin list?
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 05-31-2010, 07:42 PM
49studebaker 49studebaker is offline
Thanks for posting. I'm aware of this problem. For some reason SageTV's plugin manager is not importing the plugin into the STV. I'm not sure if it's a bug in my code or a bug in SageTV. If it's a bug in my code, SageTV's automated plugin testing failed to catch it.
I submitted a bug report to SageTV on Saturday but I do not think they will reply until Tuesday.
For now if you want to use the plugin you will need to:
Setup...Detailed Setup..."Import SageTV Application Package(.STVi File)"..."SignalOnOSD.stvi".
Old 06-01-2010, 10:23 AM
I'll be watching for the update.
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 06-01-2010, 05:19 PM
I fixed the problem. The plugin should now work.
Old 06-03-2010, 01:53 PM
Yep. Thanks!
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 09-20-2010, 12:16 PM
jpaddock3000 jpaddock3000 is offline
I have a question about expected behavior. I'm noticing that any channel that works, shows 100% signal. My TV has a built in signal strength meter, but it always shows around 5 to 6 bars, sometimes 8 or 9 if it is a good channel, but never 10 bars. My question, why does this plug-in show 100% all the time? For the one station that I don't get very good reception to, I see the meter jumping around 4 and 5% and every now and then jump to 100% and then back to 4 and 5%. Again, this doesn't make sense how I could have perfect signal for half a second. Also, how much signal is needed to get a picture? Since it is digital I figured if you had any signal, you would have picture.
Please advise.
Server - Windows Home Server: Sage 7.1.9 HVR-2250 and HD Homerun Dual Tuner, Intel Core2Duo 2.4GHz, RAM 4 GB, HD OS/Movies/Music/Pictures:500GB (SATAII) TV:1TB (SATAII),
Clients - 2 x HD-300, 3 x MediaMVP
Old 07-23-2011, 07:44 PM
filupmarley filupmarley is offline
This plugin doesn't seem to work with Phoenix. Any idean?
Old 07-23-2011, 11:08 PM
jorton jorton is offline
This plugin is for the default Sagetv UI, it will need to be ported over to work with the Phoenix UI replacement.
J
Old 12-14-2016, 05:13 PM
jwilson56 jwilson56 is offline
I would like to use the SAGETV3 skin in SaveTV Version 9. It all seems to work fine but I would also like to get the Signal Strength plugin working as well. It does not seem to be available from the link provided for SAGETV3. Any chance I could get the files I need if it would work with this arrangement. Thanks
Old 12-20-2016, 06:00 PM
metapath's Avatar
metapath metapath is offline
My TV also has a signal strength meter that shows weaker strength than SageTV. That's because the tuners in my server are much better than the tuner in my TV; yet another reason I never watch shows directly from ANT->TV. Signal is much better in Sage! I'll bet you're in the same situation.
signal strength jerryb33 Hardware Support 2 03-22-2010 12:11 PM
On-screen signal strength? Dingdul SageTV Software 10 08-07-2009 09:26 PM
Signal Strength Monitor benjamintm The SageTV Community 3 11-26-2008 11:58 AM
Signal Strength eded9698 SageTV Beta Test Software 5 12-06-2006 06:03 PM
Signal strength...? David81 Hardware Support 3 08-24-2005 08:29 AM
