SageTV HD Theater - Media Player Discussion related to using the SageTV HD Theater as a Media Player, i.e.: in use while not connected to a SageTV server. Questions, issues, problems, suggestions, etc. relating to using a SageTV HD Theater as a Media Player should be posted here. Use the SageTV Media Extender forum for issues related to using it while connected to a SageTV server. |
HD300 not retaining settings?
Every time I power cycle the HD300 it looses all the initial settings, this is happening with the production firmware and latest Beta. I hope this is not by design, because it is tiering to enter all the connection and network settings every time it gets unplugged. The Sage Extender settings do not reset on power cycle.
Thanks for any help
Server: Sage 9; 8TB, i5 4690k 16GB DDR3 2XHDHR3, Windows 10 PRO 64BIT Client 1: HD300; Panasonic TC-P65S64; Client 2: HD300; Samsung 46" LCD; Client 3: HD300; 60" LCD; |
How are you power cycling it? Do you mean pulling the plug?
It is supposed to save settings between power resets. Next time, try entering & exiting the Setup and Detailed Setup menus before unplugging it -- exiting one or both of those menus should force a properties save so the settings will be remembered. (It should save automatically periodically too.) If it continues not saving settings, I suggest contacting SageTV. - Andy
I am pulling the plug, usually after a lock up. It seems the settings never save even after days of using it. I will do some more testing when I get home and contact support if needed.
If you are running Sage as a service you need to make sure that Sage can write to the files in the client directory. In my case, this means that I had to change the owner of the file to Administrators and group to SYSTEMS because even making them writable for everybody did not work until I changed the owner and group.
Constantly Loosing Video--Retaining Audio | scm | SageTV Media Extender | 2 | 04-21-2008 02:50 PM |
convert DVD audio to MP2 while retaining menus | navels | SageTV Media Extender | 1 | 05-20-2007 02:53 PM |
Exporting STV Import and retaining references | fafurd | SageTV Studio | 6 | 01-22-2007 04:13 PM |
Retaining Recording Detail Info After Video Compression | mayamaniac | SageTV Beta Test Software | 13 | 10-24-2006 12:44 PM |
Retaining STV Imports after Upgrading SageTV | dbfresh23 | SageTV Software | 2 | 03-05-2006 12:53 PM |
