Hauppauge 2250 acting strangely
A couple of months ago I upgraded my WinXP server with Windows 7 and did a new install of SageTV, and I'm using the same Hauppauge 2250 and HD-PVR I used with the XP server. Lately I've been seeing intermittent strange behavior from my Hauppauge 2250. (I have the 2250 set up with one tuner as analog to capture basic cable and one tuner set up as digital for clear qam.)
The strange behavior is occasionally the analog tuner records a show normally (I think) but when I play the recording, the progress bar moves 4 seconds at a time (4 seconds for every second watched.) If the show is supposed to be an hour long, I can only play the first 15 minutes of it while the progress bar shows 60 minutes. At the end of the 60 minutes on the progress bar, the show playback ends and I don't get to see anything past those first 15 minutes. I"m not sure, but it might only be recording this way when the other half of the 2250 or the HD-PVR is recording at the same time. I have the latest drivers loaded for the 2250 and the HD-PVR and I"m using the most current version of Sagetv and the most current firmware in my HD200's. Has anyone experienced this behavior?
Dave S Windows 10, Sagetv 9.2.1 64b, OpendDCT 0.5.29, 8gb ram, HDHR Prime, 3 HD300 |
I had the same issue. You need to downgrade to an older 2250 driver.
Go to here: http://code.google.com/p/tmiranda/downloads/list Download and install 22xxdrv_27323. (The name might be slightly different, it should be obvious.) Tom
Many thanks! I'll give that a try this weekend.
OK, I checked the 2250 driver on my old, XP build, and I was indeed using the older driver that you referred to, tmiranda. I loaded the old driver and I'm hoping it'll do the trick. It's difficult to tell for sure because the issue only happened intermittently with the newer driver. This seems to have solved that problem.
I did notice another problem, actually now that I think about it, it was a problem with the XP build that seemed to go away with my Win 7 build. I'm now thinking that the newer driver fixed that problem and it may have been a problem with the older driver we are both using. I restarted my server and tested my three tuners; 1 analog, 1 digital, (both on the 2250), and my HD-PVR, in that order. The analog worked fine. The digital had video but no audio. I changed the channel and the audio started working. The HD-PVR was fine. I now remember that I frequently had no audio on the 2250 immediately after boot up. Changing the channel then activated the audio and it was fine thereafter until the next shut down and re-boot. Have you run into this problem with your 2250?
No, but I do not use Digital on the 2250, only analog.
im on vista 32bit ultimate, using driver
22xx_7.9.1.28162 recording both analog and digital no problem, dont know if that helps.
Gigabyte GA-MA770-DS3/4gb DDR2/AMD Phenom 955 3.2ghz Quad Core Windows 7 64bit Home Premium Hauppauge 1600/1850/2250/colossus/2650(CableCard 2 tuner) 8tb RAID5 storage/media/other &3tb RAID5 backup storage on a HighPoint RocketRaid 2680 1tb 3 disk Recording Pool all in a beautiful Antec 1200 SageMyMovies/Comskip/PlayON/SageDCT/SRE HD100/HD300 extenders |
Thanks for the response. I'm puzzled why I'm having these issues. I'll continue to search and also research the various driver changes by Hauppauge.
Tags |
hauppauge 2250, progress bar, recording playback, recording wrong time |
HDHomeRun vs Hauppauge 2250 | Diego Garcia | Hardware Support | 16 | 02-11-2010 10:22 PM |
Hauppauge 2250 IR receiver | Oats | Hardware Support | 0 | 11-16-2009 05:19 PM |
How Is the Hauppauge HVR-2250? | DFranch | Hardware Support | 4 | 07-13-2009 03:23 PM |
SageTV acting strangely, can't wipe it from system... | Sizam | SageTV Software | 2 | 04-21-2008 06:27 PM |
Network encoder acting strangely | ldavis | SageTV Recorder Software | 0 | 05-20-2004 10:43 AM |
