Old 04-21-2011, 02:32 PM
BMT getting DVD data but no fan art?
BMT gets the data for the DVDs (description, actors, etc.), but no fan art is displayed? What do I have set wrong?
Resolved -- The Fan art subdir needed to be set in 2 different places in settings/customize -- Metadata Options and Fanart options. Fanart was correct; Metadata was not. Once corrected, it now works .
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 04-21-2011, 04:04 PM
I guess first off... are you sure bmt is doing anything? ie, if these dvds were imported with an existing .properties (from mymovies, etc), then bmt will simply skip them.
Are you sure there isn't any fanart? Did you check the fanart folder to see if there was any fanart?
Old 04-21-2011, 04:23 PM
SomeWhatLost's Avatar
SomeWhatLost SomeWhatLost is offline
are you using a UI that actually displays fan art if it exists?
NOTE: As one wise professional something once stated, I am ignorant & childish, with a mindset comparable to 9/11 troofers and wackjob conspiracy theorists. so don't take anything I say as advice...
Old 04-21-2011, 04:59 PM
Yes, I'm sure that it's BMT that's getting the text data. I don't have any other automatic download plugin.
I guess that I'm assuming that BMT's not getting the DVD box covers because they're not showing up when I view the DVD titles.
It does show the DVD cover as fan art when I manually download them using the IMDB search plug-in.
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 04-23-2011, 03:42 AM
oops...
BMT USED to get DVD data for me.
It is NOT now!
And, when I went in and got it manually, only some of the cover art shows.
When I get the art from within sage, it also doesn't show.
I looked in userdata\Phoenix\Fanart and the images are there, but when I try to view it in sage, it says it doesn't have any.
I looked in the root folder of of my DVDs and it may only be showing the cover art for those with .jpg files in that subdir-not those in phoenix.
1. How do I get BMT to get DVD data automatically again?
2. How do I get the all of the fan art to display? (It now shows up in the web view, just not sage).
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 04-24-2011, 04:23 AM
I think that I know why new data's not being added.
2011-04-24 06:12:44,375 [Timer-6] WARN  sagex.phoenix.metadata.search.TVScraperManager - No TV Scraper could handle file: SageMediaFile [sageId=11036339, sageObject=MediaFile[id=11036339 A[11036342,11036340,"! David/Ju On - The Grudge 2 (2003)/VIDEO_TS",0@0409.06:34,0] mask=D host=davidk encodedBy= format=DVD 0:00:00 0 kbps [] F:\DVDs\! David\Ju On - The Grudge 2 (2003)\VIDEO_TS, Seg0[Sat 4/9 6:34:08.434-Sat 4/9 6:34:08.435]]]
2011-04-24 06:12:44,375 [Timer-6] INFO  sagex.phoenix.metadata.search.MovieScraperManager - Scraper title-withyear1 created a query: SearchQuery [type=MOVIE, fields={YEAR: 2003,RAW_TITLE: Ju On - The Grudge 2,}, hints=Hints [hints={update_fanart: true,update_metadata: true,scan_missing_metadata: true,scan_subfolders: true,known_recording: false,import_tv_as_recording: true,auto: true,}]] for file SageMediaFile [sageId=11036339, sageObject=MediaFile[id=11036339 A[11036342,11036340,"! David/Ju On - The Grudge 2 (2003)/VIDEO_TS",0@0409.06:34,0] mask=D host=davidk encodedBy= format=DVD 0:00:00 0 kbps [] F:\DVDs\! David\Ju On - The Grudge 2 (2003)\VIDEO_TS, Seg0[Sat 4/9 6:34:08.434-Sat 4/9 6:34:08.435]]] with hints Hints [hints={update_metadata: true,update_fanart: true,scan_missing_metadata: true,known_recording: false,scan_subfolders: true,import_tv_as_recording: true,auto: true,}]
2011-04-24 06:12:44,375 [Timer-6] INFO  sagex.phoenix.metadata.search.SearchQueryFactory - Created Search Query: SearchQuery [type=MOVIE, fields={YEAR: 2003,FILE: F:\DVDs\! David\Ju On - The Grudge 2 (2003)\VIDEO_TS,CLEAN_TITLE: Ju On - The Grudge 2,EPISODE_DATE: 2011-04-09,RAW_TITLE: Ju On - The Grudge 2,}, hints=Hints [hints={update_fanart: true,update_metadata: true,scan_missing_metadata: true,scan_subfolders: true,known_recording: false,import_tv_as_recording: true,auto: true,}]]
2011-04-24 06:12:44,375 [Timer-6] INFO  sagex.phoenix.metadata.MetadataManager - search(): imdb; SearchQuery [type=MOVIE, fields={YEAR: 2003,FILE: F:\DVDs\! David\Ju On - The Grudge 2 (2003)\VIDEO_TS,CLEAN_TITLE: Ju On - The Grudge 2,EPISODE_DATE: 2011-04-09,RAW_TITLE: Ju On - The Grudge 2,}, hints=Hints [hints={update_fanart: true,update_metadata: true,scan_missing_metadata: true,scan_subfolders: true,known_recording: false,import_tv_as_recording: true,auto: true,}]]
2011-04-24 06:12:44,375 [Timer-6] INFO  sagex.phoenix.metadata.MetadataManager - Searching: Ju On - The Grudge 2 using IMDBMetadataProvider[MetadataProviderInfo [id=imdb, fanartId=tmdb, mediaTypes=[MOVIE], name=IMDb]]
2011-04-24 06:12:44,375 [Timer-6] INFO  sagex.phoenix.util.url.URLSaxParser - Parsing Url: http://www.imdb.com/find?s=tt&q=Ju+On+-+The+Grudge+2&x=0&y=0
2011-04-24 06:12:44,390 [Timer-6] WARN  phoenix.log - ERROR; F:\DVDs\! David\Ju On - The Grudge 2 (2003)\VIDEO_TS; Ju On - The Grudge 2 (2003); 11036339; Metadata lookup failed for Ju On - The Grudge 2
MetadataException [query=SearchQuery [type=MOVIE, fields={YEAR: 2003,FILE: F:\DVDs\! David\Ju On - The Grudge 2 (2003)\VIDEO_TS,CLEAN_TITLE: Ju On - The Grudge 2,QUERY: Ju On - The Grudge 2,EPISODE_DATE: 2011-04-09,RAW_TITLE: Ju On - The Grudge 2,}, hints=Hints [hints={update_fanart: true,update_metadata: true,scan_missing_metadata: true,scan_subfolders: true,known_recording: false,import_tv_as_recording: true,auto: true,}]], ]
	at sagex.phoenix.metadata.MetadataManager.getMetdata(MetadataManager.java:379)
	at sagex.phoenix.metadata.MetadataManager.automaticUpdate(MetadataManager.java:475)
	at sagex.phoenix.metadata.MetadataManager.automaticUpdate(MetadataManager.java:445)
	at sagex.phoenix.plugin.PhoenixPlugin.updateMetadata(PhoenixPlugin.java:175)
	at sagex.phoenix.plugin.PhoenixPlugin.mediaFileImported(PhoenixPlugin.java:148)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at sagex.plugin.AbstractPlugin$1.run(AbstractPlugin.java:254)
	at java.util.TimerThread.mainLoop(Unknown Source)
	at java.util.TimerThread.run(Unknown Source)
EDIT: I renamed the folders by replacing the leading '!' with a '1' and BMT is working again. But sage is still only displaying the cover art that're in .jpg files in the same folder as the DVD. BMT shows the cover art in the web interface.
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 04-25-2011, 04:45 AM
BMT is responsible for downloading fanart, but it is not responsible for showing fanart. Check out the sticky in this forum on the plugins that use bmt, since in there, you'll find many plugins that use bmt/phoenix and one of those will enable you to show fanart.
Old 05-02-2011, 03:27 PM
Resolved
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Unable to get Guide data for OTA channel that has data at Zap2it wayner SageTV EPG Service 15 07-09-2010 06:23 AM
Zap2It & SageTV: Built-in data not affected; Alternatives for EPG data not included? Opus4 SageTV EPG Service 20 08-21-2008 06:31 PM
Can I use Sage EPG data and XMLTV data on two diff. sources? CanadianEh SageTV EPG Service 1 08-12-2008 09:21 AM
DVB EPG data overwrites XMLTV data actprime SageTV EPG Service 2 11-14-2007 02:41 PM
Music data mixing with tv show data BBCritical SageTV Customizations 4 09-10-2005 11:24 PM
