Old 04-23-2011, 03:46 AM
davidk21770 davidk21770 is online now
Problems with complementary metadata tools
I just installed complementary metadata tools and disabled imdb search and read, write and edit metadata (what it's replacing).
Now, I'm having problems with fan art and tried to disable complementary metadata tools to see if the problem goes away and it says that I can't do that -- there are dependencies. BUT, IT WON"T TELL ME THE DEPENDENCIES! How do I disable it?
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 04-23-2011, 05:34 AM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
The plugins dependent on CMT are "Phoenix Fanart for SageTV" and "Upcoming Movies 2".
What problems are you having with fanart?
John
Old 04-23-2011, 06:05 PM
Fan art is not showing up for DVDs. And when I manually copied the fan art from the phoenix database to a file named dvd_folder_name.jpg in the same subdir as the dvd folder, it showed up, but something renamed the set to a different movie (From 'Ju-on: The Grudge 2' to (I think) 'The Grudge' (might have just dropped the 2))! I also lost the file's metadata. I was trying to figure out what renamed my file/folder by removing you from the mix, and couldn't remove you from the mix!
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 04-23-2011, 06:54 PM
JREkiwi's Avatar
CMT won't do anything automatically. I've just checked to confirm that fanart for DVDs does work.
I'm assuming you've got the Phoenix Fanart for SageTV plugin as that would stop you from disabling CMT.
What other plugins have you got installed?
John
Old 05-02-2011, 03:29 PM
I figured out the problem with DVD fanart. The Fan art subdir needed to be set in 2 different places in settings/customize -- Metadata Options and Fanart options. Fanart was correct; Metadata was not. Once corrected, it now works.
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 05-02-2011, 04:13 PM
JREkiwi's Avatar
That's bizarrre, because both those settings are linked to the same code.
I'll have a check of it though.
John
Old 05-04-2011, 04:57 PM
That's what I assumed which is why I didn't look into the 2nd one when I found it originally (why I missed that it was wrong).
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Plugin: Complementary Metadata Tool (CMT) JREkiwi SageTV v7 Customizations 104 03-23-2021 08:42 PM
Metadata Tools 4.x (Released) stuckless Batch Metadata Tools 39 12-07-2010 09:40 AM
Warring metadata tools davidk21770 SageTV v7 Customizations 1 06-09-2010 11:07 AM
Metadata Tools Roadmap stuckless Batch Metadata Tools 0 05-21-2010 12:41 PM
