Movie Organization is Aggrivating me!
OK,
I guess I'm still in the 'honeymoon' phase since its only been a month since I've purchased Sage, but certain things drive me nuts. I have over 500 movies recorded from my years with BeyondtV, and I keep them safe on a network storage device. Now under sage, all those are found in VIDEOS section. However, any new movies I record under sage are found in my TV section, which is just fine...but even after I've transferred the actual file from the recorded location to my network drive, its still in the TV section. This just doesn't seem right. I'd like to clear out this TV RECORDINGS list. If I move a file from the recorded location to the network drive, I wish it would also move from TV RECORDINGS to VIDEO FOLDERS....is that too much to ask?
ASUS M4A79 Deluxe | AMD Phenom 9850 Black Edition | Sapphire Radeon 7750 | 52" Sharp LED LCD TV | Xonar Audio | 4GB Kingston HyperX DDR 1066 | 64GB SSD for Win10 64-bit | 1TB HDD for Local Recording | ASUS DVD Burner | Drobo 5N (3x4TB & 1x2TB) | Hauppauge WinTV-HVR-2250 (8851) |
There are lots of options for changing this - perhaps the best is to use the Diamond UI and set up a custom movie menu item that will include both "imported" and recorded movies.
but why must i use a plugin to trick the software like that? it should just do it
why is it even like that?
I would like to ask you to check out the SageTV PDF manual that is installed with SageTV (also available to download separately). In it, there is a section that covers the video browser, including its option to treat imported recordings as either recordings or imported videos -- see page 94 of the v7.0 manual.
I think all new users should check out the PDF manual rather than ranting about something. There are probably lots of options you are unaware of. - Andy
I think you might be able to do this in the default UI but I don't know because I never use the default UI. The plugin has tons of nice enhancements, including a movie wall and is well worth trying out.
//Kids Movie //PG13+ and I personally put the new recorded movies into the correct folder myself. now, on page 94 of the manual is says Quote:
i don't want all my videos on the network to show up under tv recordings...i want them to stay in video folders like they are...which means, if i put a tv recording in the imported directly, IT SHOULD BE LISTED IN THE VIDEO FOLDER with all the other imported videos as well, right?
Then you set that setting to treat them as Imports. the issue you are seeing is that sage embeds information in the recordings about the media. Upon importing those videos back into sage after the move/rename (you SHOULD rename the files), if it finds that embedded information, it will restore it to full recording status (if you leave the setting as default). Sage treats recording folders and import folders as the same. the only exception is that it will record to recording folders.
when i record a new movie, i want it to record to the local hard drive and be accessible through the tv recordings section...after viewed, i move the movie to the network drive and would then like it to be accessible through the video folders (imported) UPDATE: after I changed the file name, I rescanned my imported directories...now, the movies in question are duplicated in TV RECORDINGS section and they still aren't listed in VIDEO FOLDERS It makes no sense
ASUS M4A79 Deluxe | AMD Phenom 9850 Black Edition | Sapphire Radeon 7750 | 52" Sharp LED LCD TV | Xonar Audio | 4GB Kingston HyperX DDR 1066 | 64GB SSD for Win10 64-bit | 1TB HDD for Local Recording | ASUS DVD Burner | Drobo 5N (3x4TB & 1x2TB) | Hauppauge WinTV-HVR-2250 (8851) Last edited by MrLarkins; 05-02-2011 at 06:35 AM. |
Please read the referenced section of the manual again because you have missed that it describes an option for you to set. As we said:
are you referring to the part that says
"TV Recordings in Import Directories are:" Choice 1 is Recordings Choice 2 is Imports is this what I'm looking for? because it is set to imports and my recorded movies are still in tv recordings, not video folders...
ASUS M4A79 Deluxe | AMD Phenom 9850 Black Edition | Sapphire Radeon 7750 | 52" Sharp LED LCD TV | Xonar Audio | 4GB Kingston HyperX DDR 1066 | 64GB SSD for Win10 64-bit | 1TB HDD for Local Recording | ASUS DVD Burner | Drobo 5N (3x4TB & 1x2TB) | Hauppauge WinTV-HVR-2250 (8851) Last edited by MrLarkins; 05-02-2011 at 03:51 PM. |
Yes. That means that they should be showing up as imports not recordings. Try changing the option to imports and running a sage scan to see if anything changes. It won't instantly change, you have to let sage rescan.
SageTV Server: unRAID Docker v9, S2600CPJ, Norco 24 hot swap bay case, 2x Xeon 2670, 64 GB DDR3, 3x Colossus for DirecTV, HDHR for OTA Living room: nVidia Shield TV, Sage Mini Client, 65" Panasonic VT60 Bedroom: Xiomi Mi Box, Sage Mini Client, 42" Panasonic PZ800u Theater: nVidia Shield TV, mini client, Plex for movies, 120" screen. Mitsubishi HC4000. Denon X4300H. 7.4.4 speaker setup. |
that may be what I'm waiting on...how come? why isn't it instantaneous?
It has to realize that they should be put in a different place. It seems it has to do with changing the location in the metadata. If you look at how BMT handles imported content you can change anything imported to recordings, but it actually has to modify the metadata to let sage know that is what is happening. Best way I can explain it.
ok, its been several hours...and I've made it scan imported folders twice...the problem remains...something isn't working as it should.
As far as I know, changing that option will only affect newly found files in import directories, not those already imported -- they are already known, so they don't need to be updated during a new scan. You are only telling SageTV what to do with recordings it finds in import directories in the future.
So, try moving them to a non-import directory, perform a scan, wait until the scan is done, then move them back & scan again. - Andy
Maybe try using bmt to take the recording property away? If possible...
Plugin Organization | scoful | SageTV v7 Customizations | 8 | 12-11-2010 11:24 PM |
Setup Menus Organization | tchapin | SageTV Beta Test Software | 9 | 06-17-2010 09:23 AM |
Media Library Organization | Stobor | SageTV Software | 1 | 08-01-2004 06:02 PM |
Content Organization? | Cayars | SageTV Beta Test Software | 2 | 03-07-2004 07:13 AM |
Organization | samson | SageTV Software | 2 | 11-14-2003 09:49 AM |
