Reduce Menu Options
Hi, I'm looking to streamline my menu subsystems. Can someone point me to a place in the manual http://download.sage.tv/SageTV_Manual.pdf that deals with this?
ASUS M4A79 Deluxe | AMD Phenom 9850 Black Edition | Sapphire Radeon 7750 | 52" Sharp LED LCD TV | Xonar Audio | 4GB Kingston HyperX DDR 1066 | 64GB SSD for Win10 64-bit | 1TB HDD for Local Recording | ASUS DVD Burner | Drobo 5N (3x4TB & 1x2TB) | Hauppauge WinTV-HVR-2250 (8851) |
You might want to look at the Diamond plugin. I think you can use it to get rid of, or at least customize, the TV and Movies menu items.
rgr that, thanks, i'll look into it
I could be wrong, but I thought Diamond was limited in that respect?
The (hopefully) upcoming Phoenix and Ortus plugins apparently will feature fully-functional menu customization.
Server: AMD Athlon II x4 635 2.9GHz, 8 Gb RAM, Win 10 x64, Java 8, Gigabit network Drives: Several TB of internal SATA and external USB drives, no NAS or RAID or such... Software: SageTV v9x64, stock STV with ADM. Tuners: 4 tuners via (2) HDHomeruns (100% OTA, DIY antennas in the attic). Clients: Several HD300s, HD200s, even an old HD100, all on wired LAN. Latest firmware for each. |
In Diamond you can definitely rename the second level TV options - presumably the name could be "" which would essentially eliminate any confusion caused by large menus.
Diamond has options to hide the main menu items (1st level) and also hide show default video views as well as the ability to create custom video views based on any of the Diamond video views (Wall, Cover Flow, List Flow). See attached. J Last edited by jorton; 06-13-2011 at 08:19 PM. |
that theme is kinda slick too, whats it called?
That's a new Diamond theme I have in the works, not out yet
![]() Should make it in the next Diamond update when we get to it. J |
OK, still wondering here. I installed the new Diamond mod...its slick. but I can't figure out how to alter the menus to suit my needs best...
for example. in diamond, the videos tab shows the following option: wall flow cover flow list flow sideways flow category flow 360 flow titles dvd/bd category playlists folders playdvd (this one is hidden down low b/c the list is so long) its be nice to remove the ones i know i'll never use and maybe bring it down to 2 or 3 options, say category, folders, playdvd only. I am able to remove the first few 'flow' options through diamond options, but how can i get rid of the rest that are sage defaults? also, the online tab really sucks...what the point here? nothing really worth watching...the PlayOn plugin was nice, until i realized that I have to pay $30 for PlayOn itself before it'll work in Sage. Can I alter the Online submenu so that instead of having: weather youtube videos channels.com more online services get hulu application to something instead like ABC NBC CBS FX Hulu I'd just like to make this work for me and my family.
ASUS M4A79 Deluxe | AMD Phenom 9850 Black Edition | Sapphire Radeon 7750 | 52" Sharp LED LCD TV | Xonar Audio | 4GB Kingston HyperX DDR 1066 | 64GB SSD for Win10 64-bit | 1TB HDD for Local Recording | ASUS DVD Burner | Drobo 5N (3x4TB & 1x2TB) | Hauppauge WinTV-HVR-2250 (8851) Last edited by MrLarkins; 06-16-2011 at 04:37 PM. |
As for the Online menu etc... Diamond does not alter those... sorry. k |
right, diamond doesn't, but this really isn't a diamond thread...its a how do I edit the menus thread...diamond was one persons suggestion.
there has got to be a way to change the options, even if I have to manually edit some config files or something...surely someone has an idea
Sorry can't help with the Online menu (ditto to jusjoken's comments) so you will have to create something (Stvi) in Studio to hide the items you don't want to see as we don't have dynamic menus in Diamond. The menus are not stored in a file that you can just quickly edit and have items show/hide has to be done in Studio at the moment. J |
ok, i'll try your suggestion...still looking for the ONLINE section answer...it could be so much better than it is. what is the limitation? podcast only?
![]() There are plugins - PlayOn, WebFeedEncoder, etc. - that let you get streaming internet content. But as far as native content, yes, it's pretty much podcast or "prerecorded/downloadable" only. You can add your own custom content - read the stickies above or the manual.
no, i didn't purchase sage thinking that...but how hard should it be to change the links from those podcasts to sites like abc and fx that hosts full episodes of shows...
Video Menu Options instead of Menu Options in SageMC | scriptx | SageMC Custom Interface | 6 | 03-20-2008 03:07 PM |
Modify the menu options? | metropole | SageTV Customizations | 3 | 05-18-2006 06:27 PM |
What are the best encoding profile options to reduce ghosting? | jimbobuk | SageTV Software | 27 | 07-16-2004 01:57 PM |
