Tuner Suggestions
I just cancelled my DirecTV service. Been a customer of theirs for the last 10 years and I don't have any complaints, they've been great. However, with 4 kids, I don't get much TV time, and frankly, thats ok, b/c I play more of my online games than watch TV.
I had a Hauppauge Colossus and an ATI TV Wonder HD 600 for over the air HD. I plan on selling my Colossus and HDPVR (and possibly my HD600) on ebay and purchasing a single tuner HD tuner. However, I'd like to take the single from my antenna to a dual tuner card. SO I suppose my question is this, what is a great dual HD OTA tuner card...and can I use the signal from the same antenna? Its a homemade one, you know, a plank of wood, hangers, etc. anyone have experience with the Hauppauge WinTV-HVR-2250 Dual Hybrid Tuner? I'll end up saving $80 / month for tv I wasn't watching anyway and several hundred from the ebay sales.
ASUS M4A79 Deluxe | AMD Phenom 9850 Black Edition | Sapphire Radeon 7750 | 52" Sharp LED LCD TV | Xonar Audio | 4GB Kingston HyperX DDR 1066 | 64GB SSD for Win10 64-bit | 1TB HDD for Local Recording | ASUS DVD Burner | Drobo 5N (3x4TB & 1x2TB) | Hauppauge WinTV-HVR-2250 (8851) Last edited by MrLarkins; 06-16-2011 at 06:28 AM. |
Yes, it's a great tuner, I wouldn't hesitate to use it for OTA. However, what I would more strongly recommend is the SiliconDust HDHomeRun dual tuner, which is a network tuner so it does not even occupy a slot. The 2250 and the HDHR are approximately the same price, so cost shouldn't be a factor.
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, Unraid 6.9.2, sagetvopen-sagetv-server-opendct-java11 Docker Tuners: 2 x SiliconDust HDHomeRun Prime Cable TV Tuners, SiliconDust HDHomeRun CONNECT 4K OTA Tuner Clients: Multiple HD300 Extenders, Multiple Fire TV Stick 4K Max w/MiniClient Miscellaneous: Multiple Sony RM-VLZ620 Universal Remote Controls |
+1 on the HDHR.
network? thats a bummer, i have no more ports open on my home network...
ASUS M4A79 Deluxe | AMD Phenom 9850 Black Edition | Sapphire Radeon 7750 | 52" Sharp LED LCD TV | Xonar Audio | 4GB Kingston HyperX DDR 1066 | 64GB SSD for Win10 64-bit | 1TB HDD for Local Recording | ASUS DVD Burner | Drobo 5N (3x4TB & 1x2TB) | Hauppauge WinTV-HVR-2250 (8851) |
Add a switch for more ports
ah, yep, but that is more $$$ now isn't it?
If you have a second unused NIC on your server you can plug the HDHR into that. Then you don't even have to worry about the additional traffic.
Wayne
i5-6400, MSI B150M Micro ATX MB, 16GB DDR3 1600, 2 - WD Green 2TB SATA Drives, Lite-On SATA 4X Blu-ray Reader, Corsair 400W 80+ Power Supply, Silverstone Sugo SG02-BF MicroATX Case, Windows 10 (64), HDHR Dual X2, Quatro and Prime, 5 x HD300 + 2 x HD100 |
Second that I direct plugin one of mine (can't really do 2 of them without allot of effort directly)
my motherboard only has one port...that Hauppauge WinTV-HVR-2250 Dual Hybrid Tune is looking like the better solution for me.
ASUS M4A79 Deluxe | AMD Phenom 9850 Black Edition | Sapphire Radeon 7750 | 52" Sharp LED LCD TV | Xonar Audio | 4GB Kingston HyperX DDR 1066 | 64GB SSD for Win10 64-bit | 1TB HDD for Local Recording | ASUS DVD Burner | Drobo 5N (3x4TB & 1x2TB) | Hauppauge WinTV-HVR-2250 (8851) Last edited by MrLarkins; 06-16-2011 at 05:49 PM. |
8-port gigabit switches can be had for less than $40. Hardly in the $$$ category. If you don't already have a switch and are running everything through the built-in ports on your router, then you really ought to add a switch anyway to keep your local LAN traffic out of the router, which is probably not optimized for high-bandwidth video streaming.
-- Greg |
To answer the antenna part of your question, if you have a working antenna now, it will still work. However, adding a splitter will introduce some signal loss, and every tuner is different (more/less sensitive), so you might see issues with a new device and splitter that you didn't see with the old setup. How long is your run of coax from the antenna to the tuner? Your first step (if the splitter causes problems) might be to try to shorten it, if possible. This is an advantage of the HDHR - you can locate it nearer to the antenna to shorten the coax length and then just run network cable back to your (switch/NIC). If that's still got problems, next step may be to introduce an amp in your line.
BTW, I had the "coat hanger antenna" too, and had a few small glitches. I recommend that you replace the coat hangers with 12ga copper (buy about 4' of 12-3 copper "Romex" house wire from your local HD/Lowes and strip out the pieces from their insulation, if I remember correctly, that should be enough linear footage). You'll see noticeable improvement and the copper won't rust. ![]() First things first, though - pick a tuner and see how it does. You might be just fine anyway.
Server: AMD Athlon II x4 635 2.9GHz, 8 Gb RAM, Win 10 x64, Java 8, Gigabit network Drives: Several TB of internal SATA and external USB drives, no NAS or RAID or such... Software: SageTV v9x64, stock STV with ADM. Tuners: 4 tuners via (2) HDHomeruns (100% OTA, DIY antennas in the attic). Clients: Several HD300s, HD200s, even an old HD100, all on wired LAN. Latest firmware for each. Last edited by pjpjpjpj; 06-17-2011 at 05:34 AM. |
yea, the above dual tuner doesn't require two inputs or a splitter. I may give the copper a try, if i get glitches...however, i do have an amplifier on it.
Of course, I don't know how the internal wiring is done - do they just split it inside after the jack? I'm sure someone here knows....
Server: AMD Athlon II x4 635 2.9GHz, 8 Gb RAM, Win 10 x64, Java 8, Gigabit network Drives: Several TB of internal SATA and external USB drives, no NAS or RAID or such... Software: SageTV v9x64, stock STV with ADM. Tuners: 4 tuners via (2) HDHomeruns (100% OTA, DIY antennas in the attic). Clients: Several HD300s, HD200s, even an old HD100, all on wired LAN. Latest firmware for each. |
I have to chime in with the Avermedia Duet for OTA use. I have 2 of these in my WHS SAGETV box for a total of 4 tuners & have had great luck with them. At least with my OTA stations the Duet seems to lock on to the channels faster & the signal is more stable then the 2250's. I had 2 of those in my box & traded them out for the Duet's & never looked back. I have been very happy with the Duet's.
Phil
SageTV v7.1.9 Gemstone WHS + 3 HD200's, 1 Client & 1 Placeshifter WHS - Dual Xeon 2.8ghz - 3gig ECC Ram - 25 Drives - 30 Terabytes Blu-ray Titles 498 HD-DVD Titles 166 DVD Titles - Too Many To Count.. |
9 tuner system. Need help / suggestions. | joe4 | Hardware Support | 16 | 11-10-2009 11:22 AM |
Dedicated tuner for LiveTV - suggestions? | wado1971 | SageTV Software | 6 | 04-20-2008 10:33 PM |
Tuner Card Suggestions | JayeTH | SageTV Linux | 2 | 01-13-2007 12:54 AM |
TV Tuner Suggestions | ausm | Hardware Support | 5 | 03-30-2006 04:57 PM |
Tuner Suggestions? | polarhyte | Hardware Support | 3 | 09-17-2005 05:58 PM |
