Old 06-25-2011, 02:19 PM
MrLarkins's Avatar
MrLarkins MrLarkins is offline
Setup of Automatic Recordings
I need help with setting up automatic recordings. I'd like to be able to create a recording schedule for certain movies that aren't in the program guide schedule yet. How is this done?
ASUS M4A79 Deluxe | AMD Phenom 9850 Black Edition | Sapphire Radeon 7750 | 52" Sharp LED LCD TV | Xonar Audio | 4GB Kingston HyperX DDR 1066 | 64GB SSD for Win10 64-bit | 1TB HDD for Local Recording | ASUS DVD Burner | Drobo 5N (3x4TB & 1x2TB) | Hauppauge WinTV-HVR-2250 (8851)
Old 06-25-2011, 03:56 PM
You can add a favorite by title. Go into the Manage Favorites menu, and there should be a New by Title option.
Old 06-25-2011, 04:32 PM
MrLarkins's Avatar
yea, there is, but the box for title is a drop down box, not one I can type in the title of the movie.
Old 06-25-2011, 05:46 PM
Oh.. yeah.. if it isn't in the guide, then you need to add a favorite by keyword. After adding the keyword, it will ask you if you want to look for the keyword in the whole description, or title only.
Old 06-25-2011, 07:08 PM
MrLarkins's Avatar
ok, thanks, i've found it and working on it, however, when it comes to FORMAT, does that only apply if I'm doing a conversion on it? and it doesn't show an option for description or title
Old 06-26-2011, 09:29 AM
Not sure what you mean by FORMAT.
Old 06-26-2011, 11:31 AM
MrLarkins's Avatar
screenshot attached
SageTV and automatic moving of recordings BadBrad SageTV Software 2 03-03-2011 06:50 AM
Best tool to Import into TV Recordings Sage V6? - just sporadic, not all automatic graywolf SageTV Customizations 1 10-07-2010 09:07 AM
Fellow calibration freaks, setup your recordings! stanger89 General Discussion 2 09-19-2008 03:01 PM
Automatic DivX Encoding and Automatic Commercial Removal? TurboRX-7 SageTV Customizations 3 07-28-2005 09:00 PM
Automatic Recordings? Myth2Sage SageTV Software 4 01-18-2004 10:26 PM
