Old 08-21-2011, 07:28 AM
matterofrecord matterofrecord is offline
HD epg questions
Hi
I have recently got my dvb-t2 HD tuner working only to find the over the air (OTA) epg is huffman compressed. Which sage cannot decode/uncompress.
However it is possible to decode/uncompress the huffman encoding and there are some people who seem to have decoded it.
http://dvbguide.com/ - offer a freeware utility that takes a tuner grab decodes the huffman encoding and makes an .xml file for importing ( I couldn't get it to import with stephans importer although it probably would if I put some effort in and asked)
Nebula digi-tv also claim to have decompressed the huffman code as well
http://www.nebula-electronics.com/fo....php?f=5&t=208
I was wondering if anyone knows any work arounds other than using xmltv imports?
Also I don't have freesat but was thinking of getting it and I was wondering how much of the freesat epg is huffman compressed? Is it all the freesat epg or just the freesatHD epg that is huffman encoded?
Thanks in advance.
Old 08-25-2011, 12:05 PM
Oddity Oddity is offline
I would try EPG Collector to get the EPG data and use XMLTV Importer
Works perfectly for me
Old 08-25-2011, 12:58 PM
Yeah thanks oddity. I didn't know about "EPG Collector " I'll look into it. I was going to use dvbguide 0.90 but I look into EPG collector to see which is better.
I would have preffered native huffman decoding because it keeps things simpler with less maintenance.
I don't have a satelite card so I would still like to know how much of the freesat epg is huffman encoded.
thanks
huffman
Newbie questions... hardware questions bigRoN18 Hardware Support 9 10-13-2010 02:50 PM
MVP Questions... vvulture SageTV Media Extender 4 05-02-2007 04:06 PM
TV questions jayrbrown77 Hardware Support 6 10-12-2006 08:00 PM
A few questions. Moat General Discussion 7 10-11-2006 12:13 PM
some questions Vyts SageTV Software 3 06-22-2004 12:39 AM
