Old 11-30-2011, 12:04 PM
How to get an HD version of a show that I have in SD
I have lots of SD recordings that I'd like to replace with HD recordings as they air. The problem is that since I already have them recorded, I can't make them a favorite (with channels limited to HD) -- Sage won't record the new version since it already has a recording of the show. Is there a way to get Sage to make the new recording automatically? (I know that I can make them manually).
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 11-30-2011, 01:12 PM
Skirge01's Avatar
Skirge01 Skirge01 is offline
You can do this with SJQ v3. I suspect you can do it with v4, as well, but I have yet to upgrade to that version, since v3 currently does everything I need it to. If you use v3, it's as simple as adding this code to your ruleset:
# Reschedule SD recordings in HD
if [IsObjMediaFile == true && $.IsTVFile{} == true && $.IsAiringHDTV{} == false] {
   :DONEALERT "true"
   :RESCHEDOPTS "HDONLY"
   _RESCHED
If I recall correctly (I'm sure Slugger or someone else will chime in), it doesn't delete the SD version until it successfully reschedules an HD version (as opposed to after the new one has been recorded). What that means is that your show has the chance of disappearing for a few days between the time it finds the HD airing in the guide and when that day actually arrives to record it.
Software: SageTV 7
Old 11-30-2011, 02:44 PM
Tiki's Avatar
Tiki Tiki is offline
Actually, I have found that you can do this by modifying the existing favorite to restrict it to HD channels only, and clearing the watched status. When you do this, the existing recordings will no longer be marked as favorites if they weren't recorded on one of those HD channels. And, as long as the show hasn't been marked as "watched", if Sage sees it come up again on an HD channel, it will record it. You will then have to manually delete the SD version.
I have done this myself successfully.
One thing to watch out for though - if your hard drive is nearly full (or you use Intelligent Recording), Sage may delete some of these shows that are no longer marked as favorites to make room for something else. You may have to mark the old SD version as a Manual recording to prevent Sage from automatically deleting it when you run low on disk space.
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 12-01-2011, 10:17 AM
will will is offline
That is a great trick. Thanks for sharing.
Will
OS: Windows 7
Players: 5 HD300s, 2 HD200s
Old 12-01-2011, 11:45 AM
Skirge01's Avatar
Too much manual effort for me. Much easier to set up SJQ.
Software: SageTV 7
Old 12-03-2011, 04:52 AM
I never realized that sage would rerecord a favorite if it was unwatched and an HD version of a nonHD recording came up! I'm now testing that out .
Can SJQ limit channels? I only want a new HD recording from "movie" channels. Some of the shows that I want to rerecord are on all of the time on commercial channels, but I want an uncut version.
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 12-04-2011, 09:11 AM
Tiki's Avatar
The key is to make sure that Sage no longer considers the SD version that it already has recorded to be a favorite. You do this by modifying the Favorite settings to only record that show on the HD channels.
Source:
Old 12-10-2011, 05:58 AM
Ah! That makes a lot of sense!
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
HD PVR version beta version 1.6.29199 SHS Hardware Support 11 12-23-2011 11:39 AM
HD PVR version beta version 1.6.29207 SHS Hardware Support 21 09-12-2011 04:58 PM
Fall back from Version 7 to Version 6.6 remmuh1 SageTV Software 18 05-17-2011 02:53 AM
How do I remove incorrect TV show picture poster from a show mkanet SageMC Custom Interface 3 08-09-2008 11:59 AM
Which Java version is stable with which SageTV version? reboot_this SageTV Software 2 04-27-2007 06:17 AM
