No Signal
Just started having a problem with one channel. I have basic cable and am using hauppauge 2250 tuners. TBS tunes in through video source setup under physical channel 88-0-7. I remap that to channel 16 which is TBS on my cable, but when I go into the guide to watch it, it comes up as No Signal.
No idea why. Anyone where know??? mike |
Your provider may have turned off that QAM station. That would explain it.
SageTV Server: unRAID Docker v9, S2600CPJ, Norco 24 hot swap bay case, 2x Xeon 2670, 64 GB DDR3, 3x Colossus for DirecTV, HDHR for OTA Living room: nVidia Shield TV, Sage Mini Client, 65" Panasonic VT60 Bedroom: Xiomi Mi Box, Sage Mini Client, 42" Panasonic PZ800u Theater: nVidia Shield TV, mini client, Plex for movies, 120" screen. Mitsubishi HC4000. Denon X4300H. 7.4.4 speaker setup. |
But why would it play in the video source setup preview window? If they turned it off, then it wouldn't play at all. Plus I get it on another tv.
That is true. Do you have the always tune channel option set to true? Try that. It is pretty strange that it only happens on a specific channel.
Yes it's set to true.
No Signal on Everything | bastage | Hardware Support | 14 | 09-30-2010 07:39 PM |
no signal | snap46 | Hardware Support | 4 | 06-26-2009 06:15 PM |
Poor digital signal, analog signal okay, need an amp? | archcommus | Hardware Support | 8 | 05-05-2009 04:21 PM |
No Signal, Signal Strength99%?? | MiGster | SageTV Software | 1 | 07-07-2007 02:42 PM |
"No Signal" with 100% signal strength | trini0 | SageTV Software | 3 | 03-17-2006 12:01 PM |
