Old 08-08-2015, 11:38 AM
UgaData's Avatar
UgaData UgaData is offline
Client connection issue
I am trying to setup a SageTV server in a VM. I presently have a SageTV server running on bare metal. I do have 2 valid server licenses. I don't remember which SageTV license I used when I setup the physical machine.
I am having a problem getting the client to connect to the New server in the VM. There is no problem connecting to the SageTV server on the physical machine. I suspect that I used the same license for both SageTV servers.
Is there a way to get the client to forget the previous server settings? (preferably without reinstalling)
Or can I reset the license key on the Server in the VM? (without re-installing)
If I have to re-install so be it (be it the client or the server in the VM). I have had the opposite situation where I installed the same client license on 2 different machines, all I had to do was restart the server to switch between clients. (I now have 2 client licenses as well.)
Old 08-08-2015, 12:45 PM
The client should have no problem connecting to the different servers, license wize. The only check appears to be the server checking that the same client license isn't connecting from different client MAC addresses.
Old 08-08-2015, 12:54 PM
If you still need to do this then just run SageTV.exe with a parm of "REGISTER". Note must be uppercase.
http://forums.sagetv.com/forums/show...2628#post42628
Old 08-08-2015, 01:23 PM
UgaData's Avatar
I forgot to double check the windows firewall before I posted.
I can now connect with the server in the VM.
Client connection issues kcp120 SageTV Linux 2 05-29-2007 06:13 PM
Client connection issue dvd_maniac SageTV Software 2 09-01-2006 10:46 AM
IP connection issue with MVP and Sage sharing one cat5 cable matt91 Hardware Support 3 03-21-2006 02:11 PM
Connection issue? polarhyte SageTV EPG Service 22 01-17-2005 10:02 AM
Help - No 2.1 Client Connection!?! gotuitdan SageTV Beta Test Software 17 11-09-2004 09:18 AM
