Old 08-14-2015, 06:15 PM
Denali Denali is offline
Anomalies using Sage.jar v9.0.0.3 in SageTV7
1. SRE fails to load. Core dependency for 7.1.9.256. Noted in SRE thread.
2. Some EPG shows fail to show Future Airings.
3. Some Favorites fail to show all Additional Airings. Example Favorite of Lassie does not show Timmy & Lassie programs.
HTPC: Gigabyte GA-Z170XP-SLI, I7-6700, 16GB, Windows 10 Pro x64, Hauppauge HVR-1600, WinTV-dualHD, Colossus 2, Samsung 850 EVO 120GB, Seagate 3TB, WD 3TB, 3TB, 5TB, Java v1.8.0_231, SageTVx64 v9.2.1.826, Samsung UN60EH6003F, Dish ViP222K, ViewHD 1x2 HDMI Splitter.
Old 08-14-2015, 06:59 PM
Great post ... saves me the trouble of copying over to my production server as there could be other problems that we are not aware off... I really do not watch YouTube on my TV so no reason for me to upgrade.
Old 08-14-2015, 07:52 PM
May go back to 7.1.9.256 Sage.jar before I get to far ahead although I do like the snapper performance of 9.0.0.3.
Will give it a few days to see if anybody else see's similar anomalies. Don't thinks it matters but this is with Win 10 Pro.
Old 08-14-2015, 08:09 PM
I believe you cannot go back it converts the DB.... I could be wrong.
Old 08-14-2015, 09:32 PM
I saved a backup of the Sage folder prior. Just restore the original Sage.jar & lucene-core-3.0.1.jar. Also Wiz.bin.
Also found another anomaly on some programs & not others:
Old 08-15-2015, 08:29 AM
SHS's Avatar
SHS SHS is offline
You can it should have save a backup copy with a ver number, check the in C:\Program Files (x86)\SageTV\SageTV
Just Del
Sage.jar
lucene-core-3.6.0.jar
Sage.properties
Sage.properties.autobackup
SageClient.properties
SageClient.properties.autobackup
Wiz.bak
Win.bin
Restore by rename the backup
Sage.properties.SageTV V7.1.9.256 = Sage.properties
SageClient.properties.SageTV V7.1.9.256 = SageClient.properties
Wiz.bin.SageTV V7.1.9.256 = wiz.bin
Uninstall sagetv and Reinstall sagetv to get back the old Sage.jar
Old 08-15-2015, 09:52 AM
Just Del
Sage.jar
Sage.properties
Wiz.bak
Win.bin
Thanks SHS I will keep that in mind if I ever upgrade.
It kinda hoses up my Diamond Legacy Plugin ... and that is the one I use because it is simple and I can easily organize my seasons.... So no chance of me upgrading.
Old 08-15-2015, 02:27 PM
Did you enter your license key the new way:
http://forums.sagetv.com/forums/show...&postcount=177
Old 08-15-2015, 02:36 PM
Yes, I thought of that. I had guide data out 12 days. Since using the updated jar method it should not matter. It was not all programs but many.
Old 08-15-2015, 09:14 PM
MrD MrD is offline
Be careful with recordings.... (i.e. have a backup if you care).
An enforce limit bug (or the fixing of the bug) in a Sage v7 or Sage v9 causes Sage v9 to delete 90% of my Daily Show recordings.
[size=1]-MrD
Linux Server 7.1.9 (1)HD300 (1) HD200 (1) HD100 (2) PC Clients
Intel Xeon L? 32Gb
CetonTV cable card /FIOS
Old 09-04-2015, 04:42 PM
jm9843 jm9843 is offline
This is somewhat alarming. Has anyone else seen this or believe that it's something to be concerned with?
Old 09-04-2015, 05:53 PM
Of note so far in use experience here:
EPG data is presenting some strange results in v9.
It seems every actor/actress listed as being present in a given program(example is from Falling Skies) were playing the role of the same character when viewing program details. Issue is present on new and old recordings alike.
I'm guessing this has to do with V9 not "elegantly" handling the lack of data that the GoogleEPG is providing to V8 users.
Also of note, the Recording Scheduler seems to not have a memory between system restarts. We're not seeing any upcoming scheduled recordings displaying on SageTV until (more than) a few minutes (depending on settings for look ahead) after the Server comes back online, making me think it has to rebuild the recording schedule upon restart. Not sure if that is working as intended or not, but thought I'd mention it.
Old 09-04-2015, 06:27 PM
The first time I tried to do the upgrade, it completely wiped out the wiz.bin and reimported everything into the archives. Reverted it and tried again, recordings made it through that time, took about another 12 to 16 hours before all of the tuners started working properly again, on their own.
Old 09-04-2015, 06:43 PM
Same as I noted in post #5
Old 09-04-2015, 08:59 PM
wnjj wnjj is offline
V9 lets you dump the wiz.bin file to an ASCII file (dump_db_on_startup=true). Maybe a look at that will reveal if it's a DB corruption but it's likely a bug in code that got modified for OS.
Old 09-05-2015, 08:11 AM
SHS's Avatar
SHS SHS is offline
It most like just a bug I see the same thing as well
Old 09-06-2015, 09:33 AM
sacrament055 sacrament055 is offline
Not sure if this is related but I thought I'd mention it here. I have 5 ATSC tuners and I have Merit set to prefer my higher quality tuners and that has been working as far as I know until I moved to the new sage 9 jar.
Not quite sure if the Merit is not opposite (lower number is preferred) or if it's random but I keep seeing it pick a tuner that has Merit of 0 instead of a tuner that has Merit of 7 when there's nothing else recording.
Old 09-13-2015, 09:44 PM
I think I figured out the Actor/Character repeating issue.
There were new fields added to the "Person" table for wiz.bin version 0x4F and above. My 7.1.9 version was using 0x4B and V9 is 0x55.
    if (ver >= 0x4F)
      Wizard wiz = Wizard.getInstance();
      extID = in.readInt();
The extID field is used to match actors to their roles in SeriesInfo.java:
  public String getCharacterForActor(Person actor)
    if (actor == null) return "";
    for (int i = 0; i < people.length; i++)
      // Resolve aliases as well so they match
      if (Math.abs(people[i].extID) == Math.abs(actor.extID))
        return characters[i];
    return "";
The issue is when the V7 db upgrades to V9, all of the actors have an extID of 0. So when the match takes place, the first actor in the DB matches the ID of the actor in the show. So what's needed is if the actor extID is 0, fall back to the other string search "guessCharacterForActor" instead:
    if (actor.extID == 0) return guessCharacterForActor(actor.name);
    return "";
Old 09-13-2015, 10:31 PM
Why is the in.readInt() returning 0 on the conversion and not the version 7 extID?
Old 09-13-2015, 10:48 PM
The ver variable is read from the DB file so in.readInt() isn't called when reading the V7 db. Then the default of 0 is written when it gets saved. I'm assuming some extID's get fitted with the correct values over time.
Sage.properties file in SageTV7 wayner SageTV Beta Test Software 8 05-25-2010 08:16 PM
SageTV7, Win7 and UAC wayner SageTV Beta Test Software 1 05-20-2010 05:54 PM
Flagging guide anomalies? zoundz SageTV Software 5 07-29-2007 08:27 AM
Favorite Priority Recording Anomalies RAlfieri SageTV Software 6 04-09-2007 10:33 PM
Favorites recording anomalies Neo SageTV Software 2 01-08-2006 08:19 PM
