Old 01-07-2016, 06:26 AM
pjpjpjpj pjpjpjpj is offline
DVD and BD ripping... latest?
What software is everyone using these days? Is there anything left that's truly free and still works well? I just want to extract the main movie from my discs, preferably into an MKV container.
I had used (free) DVDFab in the past (ripping to native structure then using Handbrake to make MKVs) but it eventually hits a wall and requires payment, and I'm afraid of paying for a product that might get squashed by the feds any minute (based on their past issues).
I had used MakeMKV, which I was led to believe was always free, but it now gives me a "no longer valid, please purchase" message. Am I missing something?
I've searched around and seen a plethora of supposedly free options but they either seem really sketchy or turn out to be only a trial period that won't even allow a single full rip.
If I'm going to buy something, I would prefer a single, lifetime payment, for something I'm confident won't be a fly-by-night, gone-tomorrow product...
Responses (or even PMs) appreciated.
Old 01-07-2016, 07:02 AM
Go to the website/forums, they post a new key every month. It's "free while in beta" which it's been for years now with no signs of ever changing.
Or just install the latest version if you're out of date.
Old 01-07-2016, 07:33 AM
poto poto is offline
Another foss option that works well...
https://mkvtoolnix.download/index.html
Old 01-07-2016, 08:28 AM
That doesn't support decrypting Blu-ray's. I also don't think it supports parsing Blu-ray structures.
What I used before I started using MakeMKV was Clown_BD (not to be confused with Clone BD), which is free and based on tsmuxer and eac3to. It works but needs something like AnyDVD doing the decryption in the background.
Clone BD also works, but isn't free and needs AnyDVD as well (both from Slysoft).
Old 01-07-2016, 08:49 AM
I thought I had tried that, but maybe my brain is just too foggy these days. Thanks, I'll look into it.
Old 01-07-2016, 12:22 PM
They don't always have a new version out, sometimes you have to go to the forum and get the new key to register it again.
Old 01-07-2016, 01:59 PM
SHS's Avatar
SHS SHS is offline
I just use DVDFab ripper to MP4+AC3 there always Slysoft CloneBD, The problem you run to is cinavia and PS3 and 4.
Old 01-07-2016, 06:47 PM
trk2 trk2 is offline
The only thing that keeps MakeMKV from being the perfect solution is Sage not recognizing forced subtitles in mkvs.
Old 01-08-2016, 07:30 AM
valnar valnar is offline
If this is something you plan to do a lot, pay for AnyDVD-HD. It always works.
Client 2: HD300 on Vizio 40"
Old 01-08-2016, 11:18 AM
Skirge01's Avatar
Skirge01 Skirge01 is offline
I saw that the opposite way, in that it's the only thing which keeps Sage from being the perfect solution. That's precisely why I have Kodi installed alongside Sage. Let's be honest here, Sage is one of the few pieces of playback software which doesn't support embedded subtitles.
Software: SageTV 7
Old 01-08-2016, 11:23 AM
It works on the extenders just fine.
Old 01-08-2016, 11:58 AM
Except it doesn't obey the Forced or Default attributes in MKV.
Old 01-08-2016, 01:04 PM
I agree and use this for movies, however this doesn't work for episodic content, tv shows or movies with multiple versions (eg. theatrical & director's cut) since Sage defaults to the longest playlist. It would be awesome if there was a workaround that allowed you to configure multiple playlists from the same folder structure to be selected from the default TV/Movie view in Sage.
Old 01-08-2016, 01:16 PM
I was just referring to the decryption capabilities since AnyDVD doesn't create MKV files anyway.
Old 01-08-2016, 01:51 PM
jm9843 jm9843 is offline
For you guys doing offline Blu-ray libraries: what kind of practical hard disk requirements are there (e.g. # of titles per TB on average)? And are you doing full rips or just the main feature/primary audio track?
If I take the plunge I wouldn't be interested in doing any re-encodes.
Old 01-08-2016, 02:02 PM
Figure ~25GB/movie for the main movie.
Old 01-08-2016, 03:00 PM
SHS's Avatar
SHS SHS is offline
Not me
My is 3GB or less per movie, My bit rate around 2000/ to more the 2500 with AC3 5.1
I have just over 700+ Moive
I have just over 110 TV Show which that dose count all other season for each show.
I have just over 88 Music Albums by group which have more then one then album.
I have just over 170 Home Video
I have just over 3000 Photo
All cross 2x2TB drive and still have about 1TB to go to fill it up with more Pron Heaven
Old 01-08-2016, 03:13 PM
Skirge01's Avatar
I just checked my library and I'm averaging exactly that for movies. These numbers are pushed to 25GB by very large movies, though, such as LotR (dual discs into a single file) and 3D movies. My largest rip is the full 1980 mini-series Shogun, which is 7.5 hours long and 88GB.
For TV shows, I'm averaging ~10GB/episode.
All of these are uncompressed, so full Blu-ray quality, with subtitles and HD audio plus the embedded core audio track.
Software: SageTV 7
Old 01-08-2016, 03:18 PM
SHS's Avatar
SHS SHS is offline
But you also have 24TB or way more
Old 01-08-2016, 03:45 PM
That's what I was missing. I had never looked at their forum.
ripping TV BDs drewg General Discussion 3 03-24-2012 08:59 AM
ripping to movie only sleonard General Discussion 14 05-31-2011 11:36 AM
DVD/BD ripping question Biggen General Discussion 4 10-18-2010 03:21 PM
DVD ripping Homebuilder SageTV Customizations 11 11-15-2006 02:58 PM
DVD Ripping, Burning and OTR Spies SageTV Software 2 08-18-2005 12:05 PM
