Sage Update 9.0.8.429 (Important Update)
In 9.0.7, I introduced a fairly bad plugin bug, that basically would leave your upgraded plugins in a bad/corrupted state... Several people, including myself have been hit with this. I recommend updating to this release BEFORE upgrading any other plugins.
Here's the JAR (you can just overwrite your current jar with this one) https://bintray.com/opensagetv/saget...-9.0.8.429.zip If you are running unRAID set the version to 'latest' or '9.0.8.429' and restart the container. The linux installers have been updated. I'm sure the Windows installer will get updated fairly soon as well (hopefully ![]() I also think this release includes the following fix, "Fixed bug in the EPG license detection logic"
If that build just happened this evening, you would be correct. That commit fixes a problem at least two users reported when using XMLTV plugins. One of the values that also means we don't have a key in WarlockRipper is NOKEY and we were not checking for it, so it was making WarlockRipper think we might have a valid license, so it was going to do a time sync, but when it tried to connect, it couldn't and would exit with an error to that effect. Also, as an end result, the guide data would not actually update using the plugin.
I would have liked to add this to CHANGELOG.md, but I'm getting a little confused about that piece right this moment. Would we want to increment the minor version every time someone releases a version for Windows or Linux and a developer commits some new changes?
SageTV v9 Server: ASRock Z97 Extreme4, Intel i7-4790K @ 4.4Ghz, 32GB RAM, 6x 3TB 7200rpm HD, 2x 5TB 7200rpm HD, 2x 6TB 7200rpm HD, 4x 256GB SSD, 4x 500GB SSD, unRAID Pro 6.7.2 (Dual Parity + SSD Cache). Capture: 1x Ceton InfiniTV 4 (ClearQAM), 2x Ceton InfiniTV 6, 1x BM1000-HDMI, 1x BM3500-HDMI. Clients: 1x HD300 (Living Room), 1x HD200 (Master Bedroom). Software: OpenDCT :: WMC Live TV Tuner :: Schedules Direct EPG |
![]() I'm open to suggestions.
I think the most reasonable approach would be if you are pushing and the latest version in that log is already published, then you would need to increment the version and start a new version entry.
When i build the windows files i also need to match the version before build and then create PR i guess as this changes the project files that hold the version....even tho the windows files didn't change. But otherwise the version numbers across the release will not match. eventually i want the msbuild scripted solution to use a common version file so i don't need to update 4 locations before build. Open to suggestions. k
If you wish to see what I am up to and support my efforts visit my Patreon page |
I've edited the docker with the new version number added to the enviroment variables in the advance view but it doesn't update. It says "Total Data Pulled: 0 B. When I check the version with the mini client it shows 9.0.7.xxx. The command window has this:
root@localhost:# /usr/local/emhttp/plugins/dynamix.docker.manager/scripts/docker run -d --name="stuckless-sagetv-server-java8" --net="host" --privileged="true" -e OPT_GENTUNER="N" -e OPT_COMMANDIR="N" -e OPT_COMSKIP="N" -e LICENCE_DATA="REMOVED" -e JAVA_MEM_MB="768" -e VERSION="9.0.8.429" -e TZ="America/New_York" -p 8080:8080/tcp -p 42024:42024/tcp -p 7818:7818/tcp -p 8270:8270/udp -p 31100:31100/udp -p 31099:31099/tcp -p 16867:16867/udp -p 16869:16869/udp -p 16881:16881/tcp -v "/mnt/user/apps/sagetv/":"/opt/sagetv":rw -v "/mnt/user/media/sagetv/":"/var/media":rw -v "/mnt/user/media/Media/":"/var/mediaext":rw stuckless/sagetv-server-java8 I've also tried "Version = Latest" with no change. Any ideas what I'm doing wrong? Thanks...
Athlon II Quad Core 3Ghz, 8GB Ram. 12GB Storage. 3 (x4) HDHR for OTA Across 2 Cities, HD200, 2x HD300. |
Thx Stuckless, this last time around the update succeeded.
Windows installers also updated.... see my signature.
Maybe it's just me - but I usually have to install on windows, and then run the installer again and select 'Repair' for it to work.
I get an error that some java Matrix class is not available after the first install. Repair fixes it.
PHOENIX 3 is here! Server : Linux V9, Clients : Win10 and Nvidia Shield Android Miniclient |
If its other than these then a log from the installer would be good to review k
Since updating to this version from 9.0.4.232, I'm unable to play my imported videos. When I look on the web interface, my videos are there, but showing 0.00mb in size.
Thanks in advance for any advice. I've run a repair installation and rebooted, to no avail.
Server: HP w/Intel i7-4770S CPU @ 3.10GHz , 500GB SSD, 16GB DDR3, Win 10 64-bit, 4TB of SSD for recording SageTV: 9.2 - 64-Bit Capture Devices: 2xHD Homerun Prime and HD-PVR (Comcast Premium/Music Channels) Client 1, 2, 3, and 4: HD200. NAS: Synology DS220+ 8TB (Movie Storage) Sage Add-ons: Jetty, Neilms Webserver (Jetty), Mobile Web, Play-On Plug-in, Comskip Plug-in |
Finally, if I do have a corrupted plugin, do I fix it by updating to 9.0.8, then uninstalling the plugin, and re-installing? Or is there a better approach? Thanks. |
Sage won't boot after Catalyst Update | hedly | SageTV Software | 21 | 03-09-2016 02:09 PM |
New Sage update and Gemstone | jusjoken | Gemstone for v7 | 5 | 10-05-2012 01:40 PM |
Do I need to update Sage? | LegolasX21E | SageTV Software | 1 | 04-15-2005 12:55 AM |
Hauppauge IR and any Sage update | pdjblum | SageTV Software | 0 | 12-10-2004 08:41 PM |
