Old 02-05-2017, 03:26 PM
AlphaCrew AlphaCrew is offline
How I Upgraded my entire system
I thought I would start this thread to post up my video's on my V9 upgrade path. I used the great works of many on this forum to complete my upgrade, so big thanks to them.
Big thanks to the programmers who are making V9 a viable solution in 2017 and beyond.
SageTV OpenDCT Conversion Part 1 (4K)
https://youtu.be/a9LSy6xkCBc
Upgrading to SageTV V9 With Schedules Direct Part 2 (4K)
https://youtu.be/j9e2eSRw5xQ
Old 02-06-2017, 01:12 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
Thanks for sharing!
Jeffrey Kardatzke
Google
Founder of SageTV
Old 02-21-2017, 10:15 AM
pvr599 pvr599 is offline
Although, I did a complete re-install from scratch (server held by ransomware), the video helped me a lot. Thanks so much. I wish there were more of these.
Diehard SageTV User
Hardware:
Vizio M550NV 55",GA-H67A-UD3H-B3 LGA 1155, Intel i3, 4Gb DDR3, USB-UIRT, 2x Colossus, 1 HDHR, HD100, HD200
Software - Win7 64 bit, SageTV 7.1.9, Java v6, HD100 firmware v20100212-0, HD200 firmware 20100909 0
Old 02-21-2017, 02:40 PM
sflamm sflamm is offline
What is the point of uninstalling and then reinstalling SageTV7?
If going to uninstall SageTV 7 might as well go straight to SageTV 9 (clean install).
If you want to preserver your plugins etc then you do NOT want to uninstall SageTV 7 - you want to install SageTV 9 directly on top of it. With the latest installer this should work immediately....
Old 02-23-2017, 10:25 AM
jarredduq's Avatar
jarredduq jarredduq is offline
Location: Stockton, CA - Most miserable city in the USA, SageTV makes it bearable
Could be for the codecs that are included with v7.
Server: HP w/Intel i7-4770S CPU @ 3.10GHz , 500GB SSD, 16GB DDR3, Win 10 64-bit, 4TB of SSD for recording
SageTV: 9.2 - 64-Bit
Capture Devices: 2xHD Homerun Prime and HD-PVR (Comcast Premium/Music Channels)
Client 1, 2, 3, and 4: HD200.
NAS: Synology DS220+ 8TB (Movie Storage)
Sage Add-ons: Jetty, Neilms Webserver (Jetty), Mobile Web, Play-On Plug-in, Comskip Plug-in
Old 02-25-2017, 09:38 AM
Sorry for the delay; as jarredduq mentioned it's the easiest way to get the MPEG decoder, and closed captioning in V9.
After my initial upgrade failed writing over my existing V7 installation, I didn't want or need to preserve any plug-ins, BUT when I moved my wiz.bin file over to the new installation and started up V9, most of my plug-in where again present under installed plug-ins.
I have no idea how or why that was happening, but it was indeed a brand new V7 and V9 installation (with absolutely fresh folders), and I didn't install any plug-ins.
This, as you can imagine, caused all manor of strange plug-in problems, and is the reason I brought up the entire plug-in removal thing.
As I mentioned at the end of the video to my audience, they may get away with a simple V9 over existing V7 installation without any problems, however with my setup it just wasn't the case.
Old 02-25-2017, 09:39 AM
I'm so glad it helped. Thank you.
HD Theatre can view entire WHS Mpegger SageTV HD Theater - Media Player 5 02-11-2010 06:58 AM
Just upgraded my system flavius Hardware Support 0 04-05-2007 08:24 PM
How to Fill Entire Monitor? Pegleg SageTV Software 1 02-06-2004 12:00 AM
