Old 07-03-2017, 02:14 PM
SageClient Plugins Disabled? Resolved
This is probably something simple that I'm just missing and haven't found the right terms to search on...
BUT, I just installed SageClient on my wife's laptop. I noticed that comskip wasn't showing up so I went to check plugins -- all of the plugins that I have on my main stage install are listed as disabled on the laptop client and I can't enable them (it gives me an error and suggests a reinstall)? What did I miss? Do I just do a reinstall? (I was afraid the might impact my main install).
I also tried placeshifter 1st since we're used to that from the HD300s -- but it was a bust for HD. Could that be interfering?
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 07-03-2017, 03:04 PM
You likely have to install the plugins on the client as well.
Old 07-03-2017, 05:26 PM
They show up as already installed -- thus my confusion. I was (am) concerned that it'll make changes on the server...
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 07-04-2017, 04:53 AM
Resolved
Ok... I was reading it wrong.
It looks like the Server list is there for reference so that you can pick and choose which of the server plugins to install. They install, you just can't do it from the server list (IMO, there should be a way to do it from this list so you're not going back and forth between lists trying to remember which plugins to install next -- and a button that says "make them the same!" ).
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Which plugins should we include as core plugins, if we were to auto-install plugins? stuckless SageTV Github Development 35 07-08-2016 04:01 PM
How do I re-enable all my plugins quickly after I've disabled all of them? mkanet SageTV Studio 4 01-22-2011 11:14 AM
Disabled Plugins ThePaladinTech SageTV Beta Test Software 0 09-05-2010 08:25 AM
How do plugins get into the list of plugins? michaeldjcox SageTV v7 Customizations 4 06-12-2010 03:05 AM
Q: SageClient mode w/ Sage Service not saving into SageClient.properties laurenglenn SageTV Software 2 06-17-2007 09:22 PM
