Old 07-31-2017, 08:53 AM
Zogg's Avatar
Zogg Zogg is offline
How to setup SageTV + HDHR Prime + Tuning Adapter
In a couple of weeks I am moving a few miles and have to switch from my beloved FiOS to Spectrum cable.
With Spectrum, apparently you have to use an external tuning adapter with the CableCARD, however I can't find any information on how you connect the tuning adapter and how you tell Sage to use it to change the channel for the HDHR Prime.
I did see on the Spectrum/TWC support page where it says to plug the USB cable from the tuning adapter into the PC if you are using a Prime. But then what?
Old 07-31-2017, 09:23 AM
Sage will not know that the tuning adapter exists. The HDHR Prime will handle all of the communication with the tuning adapter.
The cable coax will go into the coax input on the tuning adapter, and a short coax is required from the coax output on the tuning adapter into the coax input on the HDHR Prime. A USB cable is connected from the HDHR Prime back to the tuning adapter. The HDHR Prime communicates via USB to the tuning adapter to instruct the adapter to perform it's digital switching magic...
Old 07-31-2017, 09:51 AM
Zogg's Avatar
Ah, thanks, didn't realize it was that simple.
From what I've heard, though, I'm expecting all my cable channels to be Copy Once so I may not get much use from the Prime anymore. I'd sure hate to go backwards to STB's and HDPVR's. Or worse, WMC.
how fast can i setup hdhr-prime live TV? cat6man SageTV Github Development 7 05-01-2016 10:00 AM
Charter Cable - Tuning adapter (with Prime) KryptoNyte Hardware Support 10 10-06-2014 06:30 PM
SageTV gets no signal from HDHR Prime via SageDCT gprichardson1 Hardware Support 13 05-27-2014 10:23 AM
HDHR Dying - Is HDHR Prime any differnt for OTA other then 3rd tuner personalt Hardware Support 2 11-19-2012 03:50 PM
HDHR Direct QAM Tuning: 6.4.5 setup feedback thread Conejo SageTV Beta Test Software 0 07-13-2008 03:44 PM
