SageTV v9 Customizations This forums is for discussing and sharing user-created modifications for the SageTV version 9 application created by using the SageTV Studio or through the use of external plugins. Use this forum to discuss plugins for SageTV version 9 and newer. |
Is there a way to auto-rename shows?
I have a series that's recorded on 2 channels with one channel giving it the wrong name!
![]() Is there a way to have sage automatically rename it to what I consider to be the correct name so that I only get a single set of recordings? Something in batch metadata tools? Will a matcher do this or does that just apply to looking up the show to get the show's info? Specifically, I want recordings of "The Artful Detective" to be renamed to (title changed to) "Murdoch Mysteries". I'd love to have the correct file name too, but if it just fixes the show name (grouping), I'll be happy! Edit: I know that I can do this manually with the edit metadata plugin, but I'd like to keep the show association so that it doesn't get rerecorded and I'd like to not have to do it for each episode.
HDHomeRun x2 Cable Box via Hauppauge HD PVR and USB-UIRT 2 SageTV's HD300 Intel Core 2 Quad Q9650 @4025 MHz, 8G G.Skill Performance DFI Lanparty DK X48-T2RS Plus; SilverStone Decathlon DA1000 (died - back to an ancient enermax) eVGA 7900 GT KO RoHS -- Zalman VP900CU Cooling Synology NAS 22TB |
Certainly, BMT could do this, using an entry in the MediaTitiles.xml.
If you go into BMT, and browse for The Artful Detective, and then do a lookup on it (changing the name to "Murdoch Mysteries", find the correct metadata, and save. Then in the same screen, there is a button, 'Add Matcher' (I think), then do a filename matcher, and save it. That will ensure that the metadata and grouping for all future recordings (once the recording completes), is correct. It does not rename the physical file.
I looked at that and have used it in the past -- but I connected it with finding the correct metadata, not changing the show name! ![]() Right now, the MediaTitles.xml that sage uses is in STVs/Phoenix/scrapers but the web BMT places the updates in userdata/Phoenix/scrapers and I need to manually move them. Do you know where these directories are defined and how they should be defined? (I don't see scrapers anywhere in sage.properties or sageclient.properties). Obviously, something has changed since my install ...11? years ago... (Or, should I ask this in a new thread ![]()
Looking for a way to automatically rename movies and TV shows, including ther folders | mkanet | SageTV v7 Customizations | 21 | 02-14-2012 03:37 PM |
ver 7 auto compress is not auto compressing | sfag | SageTV Beta Test Software | 2 | 04-20-2011 09:38 AM |
Auto Clear Watched Shows | chadman | SageTV Software | 1 | 02-27-2008 11:29 AM |
Auto-anamorpic zoom for letterboxed shows | nielm | SageTV Software | 12 | 10-06-2005 04:26 PM |
prefer to not auto-flag watched shows | aristotlex | SageTV Software | 3 | 06-09-2004 12:38 AM |
