Old 11-20-2017, 10:22 AM
willieb willieb is offline
Fanart in Gemstone on UNRAID
I have had my UNRAID setup stable for about 6 months now. I have been running stock v7 UI for years but thought I might try and shake things up a bit over the holidays. I installed Gemstone this weekend and it appears to be a success. Do I have to also install something different to get fanart, though? Do I need BMT or CMT (I don’t know the difference)? I don’t want to install unnecessary plug-ins. I had it working for a short while a couple years ago under windows but I can’t remember what I did. I remember there were options and various menu items for how you get your fanart but I am not seeing any of that now. Also, is there anything special I need to do with setting up certain directories in UNRAID (I.e. outside of the sagribusiness interface) to get all of this working?
Finally, is there any sort of tutorial or explanation for how to set up different flows in gemstone? Thanks very much for any basic guidance you can provide.
Old 11-20-2017, 10:53 AM
I don't think BMT is required for Gemstone but it is VERY useful for helping to fix any errors or missing Fanart. BMT isn't something that will cause Sage to bog down as it is a bunch of web based tools that you use to access and work with your Fanart. Hopefully it will be integrated into the core Sage web UI in the future.
Have you checked out the Gemstone FAQ yet? https://forums.sagetv.com/forums/showthread.php?t=59129
Gemstone hasn't really changed from the old version for V7. So check out the threads in the old Gemstone sub-forum: https://forums.sagetv.com/forums/forumdisplay.php?f=51
Old 11-20-2017, 09:25 PM
***Edit***
OK. I have been poking around in various sage directories. Gemstone is downloading fanart but not displaying it. I will go back through the FAQs and setup guides and I am sure I can get it working. Thanks!
Old 11-21-2017, 06:02 AM
jusjoken jusjoken is online now
If u r not getting any fanart then try turning gemstone logging to debug in options and then restart, recreate the issue and upload gemstone and sagetv logs.
k
Gemstone Fanart on Multiple Clients w/Centeral Server texneus Gemstone for v9 11 02-04-2019 02:56 PM
Giving up: How to achieve these without UNRAID/Linux or Gemstone? btrcp2000 SageTV v9 Customizations 13 03-25-2018 11:32 AM
Fanart showing in folders and BMT Web UI but not gemstone? btrcp2000 Batch Metadata Tools 12 11-15-2017 01:51 PM
Multiple Clients w/Gemstone Not Displaying Fanart clarenceb5 Gemstone for v7 22 02-25-2013 10:52 AM
SageMC, Fanart, MediaScraper & Central FanArt folder structure – Help requested rmac321 SageMC Custom Interface 24 06-14-2009 02:00 PM
