General Discussion General discussion about SageTV and related companies, products, and technologies. |
sage recording conversion for use in emby
Hi,
I have a ton of old sagetv recordings, and more are created every day. When I link emby to a sage directory, the meta data is not read. Is there a way to rename the sage recordings so that emby can read the name, tell what it is and then download the metadata for it? Or... something that works like that? Also, can I run some plug in within sage to process all the recordings and cut out all the commercials? Any help is appreciated.
Main Server: AMD 64, 3000+, running xp home; 1 gig ram, 1 terra of HD space. running Sage 2.28 Client: P4 2.4, 500 gig ram, 80 gig hd, sage client 2.28 Media Server: AMD 64 3200 +, running xp home, 1 gig ram, 580 gig HD used for storing and editing and burning movies and music. Building Client: p4 2.4; 1 gig ram; 80 gig GD, 6600GT running to a mitsubishi 65 inch HiDef (planning on installing another full sage but running as a client to use remote HD turners and firewire tuner) |
Try installing the Batch Meta Data plugin which gives you the ability to edit a recording's meta data. Also the Comskip plugin will help in commercial detection.
Go to your detailed settings and set "Include season and episode number in filenames" and "Include episode names in filenames" to "Yes". Then stop your SageTV service. Edit your Sage.properties file and set extended_filenames=true. Then start your SageTV service back up. Any future recordings will be in the format "<show name> - SxxExx - <episode name>".
Server: i5 8400, ASUS Prime H370M-Plus/CSM, 16GB RAM, 15TB drive array + 500GB cache, 2 HDHR's, SageTV 9, unRAID 6.6.3 Client 1: HD300 (latest FW), HDMI to an Insignia 65" 1080p LCD and optical SPDIF to a Sony Receiver Client 2: HD200 (latest FW), HDMI to an Insignia NS-LCD42HD-09 1080p LCD |
Note that this doesn't work to make things look nice in Emby or at least last time I tried. It needs things in folders if I recall. The only solution I found was to rename / move things. I mean you can browse and watch, but the files are not organized by show or anything without a folder structure. I never got around to trying to automate renaming though e.g.with SJQ, but there are some scripts on here that will do that. Also there is a stand-alone renamer somewhere on here.
It seems like a scraper could be made in Emby to support SageTV naming, or I also thought about putting a request in to support name templates in SageTV. Anyway, I looked at it a bit a while ago, but never automated a solution. PLEX on the other hand works fine if you set the flags Taddeusz mentioned. While I prefer Emby, it had some playback issues on some devices.
Home Network: https://karylstein.com/technology.html |
Try MCEBuddy. Works for me.
I use it to monitor and process recordings in the Sage (and Playon) recording directories to
Server: Intel i5-11400 @4.4GHz 6 cores Windows10 Pro, Sage 9.2.6.976, Comskip Donators Capture: Now> Xfinity/TVEverywhere/Channels OpenDCT_0.5.32_x86. Future> remote HDHR Prime with Firmware version 20150826 Storage: 120gB SSD, 4tB HD on Server Network: Now> gb LAN; Future> 500Mb Comcast to WAN to 20Mb rural ISP. Playback: FireStick 4K, miniclient V1.9.3 Tech Level: Hobbyist Last edited by hb4; 06-10-2018 at 10:13 AM. |
You all do know that Emby now support the Hauppauge DVB/ATSC Tuner card now that about far I gotten with them how ever you do need WinTV 8 install.
There even some support for HD-PVR 2 and Colossus 2 but so far they haven't address any IR Blaster support which is one of the main things that we needed even with HDMI IPTV Encoders. |
SageTV and Emby Integration | KarylFStein | General Discussion | 3 | 12-21-2016 06:40 PM |
Recording Conversion quality and schedule | jdc | SageTV Software | 3 | 08-28-2011 02:09 PM |
Partial recording conversion question | zappedguy | SageTV Software | 0 | 11-18-2009 06:12 PM |
Odd Recording and Conversion Problem - Request help | GoFigure | SageTV Beta Test Software | 3 | 02-18-2008 11:08 AM |
Automatic recording conversion | interman | SageTV Software | 2 | 09-20-2007 09:43 PM |
