How to group movies in standard UI
Hopefully not a dumb question, but I've only been a SageTV user for about a year so there's a lot I haven't figured out yet.
I'm running the standard UI, and one annoyance is that I can't figure out how to group movies into one group or folder such as you would find multiple episodes of a particular show. Is there a way to do this, ideally with a folder called Movies or something similar? |
Not sure what you mean by group movies. Season/episode numbers don't apply to movies. Maybe you're thinking of a collections feature like Emby/Kodi/Plex? As far as I know, no such feature exists for SageTV. Probably a worthy feature to request, though.
Server: Xeon E3-1225, 32GB RAM, Open Media Vault 5, SageTV Docker Tuners: HD Homerun Quatro (OTA) Clients: NVidia SheildTV x3 |
If you use the Malore style menus (built-in to the default Sage v9), it automatically groups movies. It basically treats them like the show name was “Movie” and the episode name was the actual movie title.
This is a must have feature for me since I record a lot of movies from the premium channels. I don’t want my recording list filled with hundreds of movies. You have to go to Setup->customize, then scroll down to the extra options section near the bottom of the list to enable the Malore menus. Even if you don’t use the Malore menus, I think you can still create a separate Movie only view and tv-only view by pressing the options button on your remote and adjusting the filters.
I'm going to suggest you look at using a custom UI like Gemstone or Phoenix. Both will do what you want and will improve the look and usability of Sage overall.
I had previously created a Movies category but hadn't figured out how to filter them out of the All Recordings view, but now I have it. Thanks all for the tips!
do tell, how did you do it, from directions in the manual? what page...
Sage 9 server = Gigabyte AMD quad-core - 4 gigs - integrated ATI HD4200 chipset - SSD boot, Hitachi Deskstar show drives. HD-PVR - Colossus - Win7 32 bit. HD200/300’s networked. HDHomerun tuner. "If you've given up on Weird Al, you've given up on life" - Homer Simpson |
Then for each Movie recording, select it then select "Edit User Categories". You should see your custom category, in my case Movies, so I checked it and then Done. I did this for all my movie recordings. In TV->All Recordings, right click and pick Filtering. Then click on "Categories filtered in:None" and you should see your User Category in the right column. Check the box for your new category. Here is the trick I missed previously. On the left of the same screen, it says "Selected categories are: Included" by default. Click on Included and it will change to Excluded. So now your selected categories will be excluded from the All Recordings view. In this case since I picked Movies, all the Movies will be excluded from All Recordings. Click Done and now on the previous screen it should show "Categories filtered out: 1". Now all I see are my TV show recordings in All Recordings, and the movies can be viewed in Recorded Movies. Hope this helps. |
I use Gemstone but I'm pretty sure the following works in the regular UI.
If you put the movies you want to "group" into one folder (say, all the Star Wars or 007 movies) and pick "view by folder" in options, it should do what you want want.
SERVER/CLIENT_1--> AMD Phenom2 X4 925 2.8GHz. 8Gig mem. Asus M5A97. // Win 7 x64 // GTX 1060. //Ceton infinity 4 Comcast // SageV9.2.5.936 x64 running Gemstone // Lots of HD space. Recording to a NAS CLIENT_2--> AMD Athlon 64 X2 5400 Brisbane 2.8GHz. 4Gig mem. GIGABYTE GA-MA780G-UD3H// ATI 5570. // Win 7 x64 |
ASRock B450M Pro4 AM4 MB, Ryzen 5 2600 3.4ghz, Crucial Ballistix Gaming 32GB (2 x 16GB) DDR4-3200, EVGA GT 1030SC, WD Black NVMe SSD 250GB, 1x WD120EFAX 12TB, 1x WD80EFAX 8TB, 1x WDBH2D0040HNC 4TB, USB-UIRT, Colossus 2, WinTV-DualHD USB, Windows 11 64bit |
If you are very familiar/comfortable with the standard menu (don't want to try Gemstone or Phoenix), install the "ADM" plugin. It is just a stock menu customizer. You can rearrange all menu items, hide ones you don't want, rename them, assign custom background photos to any menu item, etc. Learn to use the "copy" mode (it's a little tricky) and you can use it to create menu items aimed at a specific folder structure on your server/network. For instance, our household has a main menu item called "Media" with submenu items that point at folders with family photos, home videos, MP3s, downloaded videos, and all our (mom & dad's) movie (BD/DVD) rips. The background photo behind the "Home Videos" item, for instance, is a family photo. We also then have another one called "Kids" (background photo is of the kids
Server: AMD Athlon II x4 635 2.9GHz, 8 Gb RAM, Win 10 x64, Java 8, Gigabit network Drives: Several TB of internal SATA and external USB drives, no NAS or RAID or such... Software: SageTV v9x64, stock STV with ADM. Tuners: 4 tuners via (2) HDHomeruns (100% OTA, DIY antennas in the attic). Clients: Several HD300s, HD200s, even an old HD100, all on wired LAN. Latest firmware for each. |
Using "Standard" Sage Thumbnails for TV and Movies | cncb | Diamond | 11 | 03-12-2011 12:52 PM |
Group movies together in SageTV Recordings list | turak | SageTV v7 Customizations | 1 | 06-30-2010 11:36 AM |
Group won't go away | Phydeaux | SageMC Custom Interface | 0 | 01-05-2009 01:44 PM |
can I group all recorded movies into a MOVIES group | Deacon Crusher | SageMC Custom Interface | 5 | 06-05-2008 12:22 PM |
Group Movies | Tyler Lloyd | SageTV Studio | 1 | 02-13-2006 01:46 AM |
