Old 09-14-2018, 06:26 AM
UgaData's Avatar
UgaData UgaData is offline
Retrieve Plugin from another install of Sage?
Is it possible to retrieve a plug-in from an old install/backup of SageTV?
And if so, where do I find it?
There is a plug-in I would like to have installed on my current setup but it appears not to be available any more. The download link doesn't work, the Developer isn't around much anymore and has indicated that it is probably just an issue with the link or permissions, but has never gotten around to fixing it.
I am sure I have a old backup of a previous Sage Server or client that had the plug-in installed.
Old 09-14-2018, 09:31 AM
tmiranda's Avatar
tmiranda tmiranda is offline
What plugin? A list of what you will need can be found in the plugin manifest.
If you have a backup of the Sage directory you can most likely recover what you need and then manually install it. Plugins typically have two parts: and .stvi which alters the user interface and a JAR file which provides Java functionality. The .stvi is located in the same directory as the SageTV7.xml file and the .jar file is located in the JAR directory.
Some plugins have other files and dependencies.
Old 09-14-2018, 11:47 AM
UgaData's Avatar
The Plug-in referenced here: https://forums.sagetv.com/forums/showthread.php?t=64589
It has been unavailable for at least a year.
Thank You for the direction. I will try this over the weekend and see what happens.
Another option maybe if someone downloaded it as part of Sluggers script.
SlimPlayer plugin install fails on GKusnick plugin scottkoontz SageTV v9 Customizations 11 01-07-2017 07:34 PM
Is it possible to retrieve lost sage key? aedgington SageTV Software 15 02-06-2013 02:02 PM
plugin, install once, available everywhere? Deacon Crusher SageTV Beta Test Software 4 07-23-2010 12:52 PM
Need to retrieve the licenses from sage rdefino SageTV Software 1 11-14-2008 08:55 AM
Retrieve Sage Cd-Key rbarr110 SageTV Software 3 02-14-2005 08:33 PM
