Old 10-26-2021, 05:35 PM
UgaData's Avatar
UgaData UgaData is offline
Missing the end of recordings
Although there hasn't been as much to record as there has in the past, recently I have been missing several minutes at the end of the recording.
I have used padding at the beginning and ending of Favorites since I started using SageTV.
I have checked and double checked that the Sage Server has the correct time. I was syncing to a Synology NAS which was getting the time from one of the Internet time servers (not sure which at the moment). I changed that so the Sage Server is sync directly with an Internet Time Server.
I am used to having issues with FOX on Sundays after a sports event, the whole nights schedule is shifted. This issue is happening on several if not all the channels I am recording on.
The shows may start up to a minute and half into the recording but I miss up to 10 minutes of the end of the show.
So, I am curious if anyone else may be seeing something similar?
I have been trying to find the episodes that are getting cut off on a streaming service, which works for some episodes but others aren't always available and Xfinity seems to be pushing everyone to use there "in home WiFi" to view randomly selected episodes. Problem is I supply my own cable modem and WiFi.
Recordings Missing reccitron SageTV Software 4 06-09-2015 02:48 AM
Missing recordings drewg SageTV Linux 2 03-19-2008 12:06 PM
Help! Missing Recordings Fusion SageTV Software 4 03-06-2008 11:42 AM
Recordings missing jjstok SageTV Software 2 04-02-2007 12:35 PM
Missing Recordings ewerx SageTV Software 2 11-05-2004 02:21 PM
