Go Back   SageTV Community > Information & Announcements > SageTV Downloads & Instructions
SageTV Downloads & Instructions This forum is for discussions containing Downloads and Instructions related to the Open Source version of SageTV. Please do not post questions in this forum.
Old 10-29-2021, 03:24 AM
Java version for 64 bit?
Just recently, I started having an issue that I believe may be related to plugins and maybe Java version (metadata losing season / episode and keeps adding the show name to the beginning of the episode name and web interface not loading it's template engine so I can't access some of the advanced tools) and am wondering what the target version of java is for Sage and it's plugins?
I am still at Java 1.8.0_211-b12 64 bit. What version should I be using?
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 10-29-2021, 03:44 PM
I used the one that came with the SageTV install.jre1.8.0_191 but any 1.8 should be ok.
Old 10-31-2021, 06:59 AM
Resolved
Thanks.
It turns out that I set an option in one of the metadata tools that appears to be buggy and is causing the problem. I went through all of the metadata setting options and found one that I had toggled a little while back. As soon as I told it to not automatically update the database with .my files it went back to working as expected :-).
HDHomeRun x2
2 SageTV's HD300
Synology NAS 22TB
Old 11-09-2021, 03:54 PM
What about alternative versions of java? I don't want to use Oracle issued verson. I prefer openjdk. Sagetv seems to not recognise when java is installed other than the auto download included by the installer. This applies only on Windows version. On Linux I can use the openjdk version without incident.
Old 11-09-2021, 09:05 PM
wnjj wnjj is offline
I replied in your separate thread: https://forums.sagetv.com/forums/showthread.php?t=66832
Windows Installer
What version of Java? cncb SageTV Github Development 2 11-03-2015 01:40 PM
version of Java korben_dallas SageTV Software 4 10-04-2015 01:14 PM
What version of Java garmpe SageTV Software 2 06-04-2008 08:08 AM
Which Java version is stable with which SageTV version? reboot_this SageTV Software 2 04-27-2007 06:17 AM
Which version of Java and where to get it? brianblank SageTV Software 6 02-06-2005 10:14 AM
