Old 12-04-2021, 12:20 PM
gdippel gdippel is offline
Installed latest Linux jar and stv (9.2.6) unable to connect to HD 300 placeshifter
I've been running Sage on a Ubuntu server for several years and decided to upgrade to the latest jar and stv due to the new weather info provided by OpenWeatherMap. I've done this several times in the past with no problems by just replacing the jar and stv files. This time however, when I restart the server, my HD 300 as well as my placeshifter refuse to connect to the server. I have a Windows client that will connect to the server but won't record/play any channels. I checked the permission of the jar and stv files, they are the same as the originals. All is well when I revert back to the originals. Anyone have any ideas?
Old 12-04-2021, 12:51 PM
wnjj wnjj is offline
What does the server log file show when you try to connect?
What version were you using before?
Windows Installer
Old 12-04-2021, 04:07 PM
I upgraded to java 11 and that seemed to do the trick. I was using 8. Thanks for the response, the server log did show some strange java exceptions so that led me to believe that was the problem.
Android Miniclient unable to connect to SageTV Linux Server ˃v9.2.2.268 El Jeffe' SageTV Software 4 11-07-2021 10:37 AM
PlaceShifter unable to connect to Server RonBoyd SageTV Placeshifter 3 09-11-2010 12:39 PM
SageTV Placeshifter is unable to connect dtshedd SageTV Placeshifter 6 06-08-2007 03:04 PM
Mac Placeshifter is unable to connect waffle SageTV Placeshifter 8 02-04-2007 08:16 PM
just installed the latest hauppauge remote ir.exe file GbrNole General Discussion 0 11-22-2004 08:43 AM
