Old 12-15-2021, 06:32 AM
graywolf's Avatar
graywolf graywolf is offline
2 crashes in a couple days - help?
I've had SageTV crash twice in the past couple days.
Any thoughts/recommendations?
Attached are the hs_err_pid logs
Old 12-15-2021, 10:17 AM
graywolf's Avatar
I am also seeing the following in the logs when I tried to Force EPG Update from the web UI.
Wed 12/15 11:16:09.086 [EPG@1213fda] SDEPG Set the system clock to be Wed 12/15 11:16:09.084
Wed 12/15 11:16:09.261 [EPG@1213fda] SDEPG Exception thrown: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was STRING at path $[935].broadcastLanguage
Wed 12/15 11:16:09.261 [EPG@1213fda] sage.epg.sd.gson.JsonSyntaxException: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was STRING at path $[935].broadcastLanguage
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:225)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.gson.internal.bind.TypeAdapterRuntimeTypeWrapper.read(TypeAdapterRuntimeTypeWrapper.java:41)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.gson.internal.bind.ArrayTypeAdapter.read(ArrayTypeAdapter.java:72)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.gson.Gson.fromJson(Gson.java:889)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.gson.Gson.fromJson(Gson.java:954)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.gson.internal.bind.TreeTypeAdapter$GsonContextImpl.deserialize(TreeTypeAdapter.java:163)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.json.map.SDLineupMapDeserializer.deserialize(SDLineupMapDeserializer.java:51)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.json.map.SDLineupMapDeserializer.deserialize(SDLineupMapDeserializer.java:30)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.gson.internal.bind.TreeTypeAdapter.read(TreeTypeAdapter.java:70)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.gson.Gson.fromJson(Gson.java:827)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.SDSession.getAuthJson(SDSession.java:686)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.SDSession.getLineup(SDSession.java:829)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.SDRipper.extractGuide(SDRipper.java:1229)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.EPGDataSource.expand(EPGDataSource.java:709)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.EPG.run(EPG.java:783)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at java.lang.Thread.run(Unknown Source)
Wed 12/15 11:16:09.262 [EPG@1213fda] Caused by: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was STRING at path $[935].broadcastLanguage
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.gson.internal.bind.JsonTreeReader.expect(JsonTreeReader.java:163)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.gson.internal.bind.JsonTreeReader.beginArray(JsonTreeReader.java:72)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.gson.internal.bind.ArrayTypeAdapter.read(ArrayTypeAdapter.java:70)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.gson.internal.bind.ReflectiveTypeAdapterFactory$1.read(ReflectiveTypeAdapterFactory.java:130)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	at sage.epg.sd.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:221)
Wed 12/15 11:16:09.262 [EPG@1213fda] 	... 16 more
Wed 12/15 11:16:09.262 [EPG@1213fda] ERROR Updating EPG Source DIRECTV Charlotte - Satellite - Charlotte (sdepg)
Wed 12/15 11:16:09.262 [EPG@1213fda] ErrorText:expand called on DIRECTV Charlotte - Satellite - Charlotte (sdepg) at Wed 12/15 11:16:00.164 expandedUntil=Wed 12/31 19:00:00.000 scannedUntil=Sun 8/17 2:12:55.807
EPG Expanding DIRECTV Charlotte - Satellite - Charlotte (sdepg) at Wed 12/15 11:16:00.167
Old 12-15-2021, 11:13 AM
jusjoken jusjoken is offline
You could try moving from Java 7 to Java 8
SD in the UK - how many days? syrel SageTV EPG Service 6 06-12-2018 05:04 AM
Version of MM being used with SMM these days? nateziemann Sage My Movies 1 04-04-2011 09:49 AM
600 days... Trepidati0n SageTV Software 1 09-27-2010 11:47 AM
Random crashes every few days.....suspect Java henk99 SageTV Software 3 04-29-2005 07:50 PM
