Old 01-12-2022, 11:40 AM
Remote Access Video Problem
I am currently in FL and I trying to get the Android Client to work remotely to my house in NC. I can connect the client on multiple devices but I cannot get video to play when I select a Channel for TV or a video. I just get a blank (Black) screen. I am on 9.2.8 on the Server and the latest Android Client. I also do not seem to be able to play video on the the Window x64 Placeshifter Client. Opened port 31099 on my router already. Other thoughts?
Old 01-12-2022, 06:12 PM
KryptoNyte's Avatar
On the android device, did you try switching decoders? If you're using Exoplayer, try IJK Player instead, or vice versa.
While playing a video I believe you can bring up the overlay (long press 'select' maybe?) and then select the button that looks like a video camera to switch decoders. You may need to exit the video and re-start it to get the new decoder to take affect.
I can't explain the issue with Placeshifter.
Old 01-13-2022, 09:13 AM
Thanks but that did not do it. Still investigating.....
Old 01-13-2022, 09:23 AM
jusjoken jusjoken is offline
Are you able to check the SageTV log files on the server. Perhaps some errors there may help to resolve
K
How To Access Remote Settings OldPCGUY SageTV Software 1 07-11-2017 08:00 AM
Remote access via Placeshifter hb4 SageTV for unRAID/Docker 3 03-16-2017 05:58 PM
Remote Web Access problem mrrrl SageTV Customizations 1 11-21-2006 01:15 PM
Remote Drive Access? jimbruskalski SageTV Software 29 05-17-2006 10:14 AM
Networking and Remote Access akenis General Discussion 1 10-27-2005 04:53 PM
