Old 01-14-2022, 01:29 PM
bnflaherty's Avatar
bnflaherty bnflaherty is offline
Slowness browsing through imported videos
Good day!
I've come across an issue and wanted to get some input - I originally chalked it up to a NAS issue - but it's now fine.
If I go through my Recorded videos - all is well
However, when I try to traverse the imported videos - it just bogs down
Stats on that is as follows:
1,273 Files, 53 Folders - 337 GB
Most of those files are on a NAS some are local to the Sage box.
This is primarily an issue on an HD300.
Any thoughts would be appreciated.
Old 01-14-2022, 05:11 PM
jhkoenig's Avatar
jhkoenig jhkoenig is offline
You may be running into Java garbage collection. I had a similar slowness browsing large lists until I upgraded from 32bit to 64bit SageTV and bumped up the Java heap size. Once I did that, the slowness/freeze ups vanished.
Win10@16GB RAM, 30TB Disk across 6 disks. 2 Prime tuner units
Sage v9 (64bit) using OpenDCT to control the Primes
2 HD-300s, an Android mini-client, and a Windows client
Old 01-14-2022, 07:25 PM
graywolf's Avatar
graywolf graywolf is offline
Curious, what did you bump it up to and what is the size of your wiz.bin?
Old 01-14-2022, 07:58 PM
jhkoenig's Avatar
My wiz.bin is only 124M. I moved my heap up to 1400Hex. Using 3 clients at once is rock solid!
Browsing non-imported folders myrrh55 SageTV Beta Test Software 2 05-22-2010 08:50 AM
Browsing My Videos on client is slow phareous SageMC Custom Interface 4 12-08-2009 09:42 AM
Cursor keeps jumping to top of screen when browsing imported videos OverClock SageTV Software 7 04-10-2009 10:44 PM
Browsing non-SageTV videos otakucode SageMC Custom Interface 0 06-22-2008 04:45 PM
Browsing imported videos, have to click OK twice just to view... travisbell SageTV Software 1 02-26-2007 01:17 AM
