Old 02-20-2006, 05:01 PM
disgust disgust is offline
need hd screenshots-- hardware advice?
I'm working on a Lost site. I need to capture high def screenshots to have on the site. right now I have a standard PVR-250. however, right now I'm just set up to recieve standard def signals.
here's an example of one of the screens (direct from source, I didn't change the dimensions, etc):
at first I was mostly content with this quality, but then I saw the screens from another site.
how are they achieving that sort of resolution? I thought "true" hd capture wasn't even possible? are they just upscaling the resolution of images?
in short: if I want to get the highest quality possible, should I be looking at hardware to capture in hd? can hardware capture in true hd-- ie, will I have a video that's 720/1080 pixels tall? what kind of hardware would you suggest for that? how much would I be looking at?
Old 02-20-2006, 05:10 PM
Grabbing screenshots out of a transport stream is trival. Just get yourself an OTA HD card, record the show, and grab some frames.
http://www.pcalchemy.com/index.php/c...e59d2a26081394
-edit
FWIW, I don't think either of those is HD.
Old 02-20-2006, 05:13 PM
what is a "transport stream"? and "OTA"? sorry, some of this may be over my head.
if I buy one of those cards, will the quality of the screens improve significantly? can I record true hdtv with them, at the native 1080/720 resolution? how big are episodes like that?
Old 02-20-2006, 05:28 PM
Transport Stream - a holder for MPEG-2 video and audio. It's like the MPGs Sage records, but designed for broadcast.
OTA - Over The Air, broadcast TV.
The quality will be better, I'll leave the qualifiers up to you:
Ignore the combing, this is video so better than film sharpness wise (Lost would be Film), the combing would be cleaned up by the deinterlacer.
Yes you can record the full 1080i/720p.
About 9GB/hour.
Old 02-20-2006, 05:43 PM
ToxMox's Avatar
ToxMox ToxMox is offline
Looks to me like they scaled it up. I scaled your original file up to roughly the same size as the second image and the one I scaled looks a little better than the larger one from the other site.
Old 02-20-2006, 05:48 PM
thank you both. I'm still a bit torn on whether or not it'd be worth updating to an hdtv card.
another question: I don't have an hdtv capable tv. if I get an hdtv card in my htpc, is that enough? or do I need additional equipment?
Old 02-20-2006, 06:01 PM
Wheemer's Avatar
Wheemer Wheemer is offline
What are these screenshots for? Seems like a lot of work, when that screenshot you grabbed looks pretty good to me.
Old 02-20-2006, 06:03 PM
for a lost fansite I realize it's a decent bit of work, but considering that I'm doing all this work, I'd like them to look as good as possible
Old 02-20-2006, 06:05 PM
Plus it's 1.33:1, not 1.78:1 like an HD capture should be. It really should be 1280x720 if it's a true HD capture from ABC.
It's enough to record HD (don't want to use the term "capture"*), and grab screenshots. But without an HDTV, you won't be able to watch it in HD (unless you're watching on your monitor).
*Capture, to me implies the grabbing of raw, uncompressed video from an external source. Capturing HD is completely impractical at the moment.
Old 02-20-2006, 06:15 PM
Wheemer's Avatar
Make sure you post a link to the site when it's ready... I love lost.
Old 02-21-2006, 09:14 AM
clmolnar clmolnar is offline
Yes, looking for link!
