Go Back   SageTV Community > SageTV Products > SageTV Recorder Software
SageTV Recorder Software Discussion related to the SageTV Recorder application produced by SageTV. Questions, issues, problems, suggestions, etc. regarding SageTV Recorder should be posted here.
Old 07-07-2003, 07:06 PM
robsmith robsmith is offline
Up/Down buttons (Creative DVCR)
Hi,
I have registered the software, as it is a better alternative to Creative's bundle.
The up / dowm buttons do not change the channel on the DVCR as expected.
Is there a way to enable the DVCR remote to work with Sagerecorder?
Bob
Old 07-07-2003, 08:16 PM
pbarrette pbarrette is offline
Hi Rob/Bob,
I had the same problem initially. Though I discovered that if you scroll down the commands list, you will find two functions called "Up/Channel Up" and "Down/Channel Down" as well as "Right/Volume Up" and "Left/Volume Down" which correspond perfectly to the DVCR's remote buttons.
Map those to the remote and I assure you that you will be pleased.
pb
EPIA M10000 (1 GHz) Nehemiah, VB-DVCR (Standard Drivers), WinXP
Old 07-09-2003, 07:15 PM
Where are these options?
Hi,
Thanks for the reply. I cannot seem to find where these options are located. Could you enlighten me?
Old 07-09-2003, 07:31 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
Those settings mentioned are for SageTV, not SageRecorder. But I think Girder has support for the Creative remote, and if so, you can then use that in conjunction with SageRecorder.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 07-10-2003, 05:51 AM
Any plan to fix the up/down buttons in SageRecorder? The number buttons work, but Up/Down does not.
Are there any details on setting up Girder to work with the Creative Remote?
Bob
Old 07-10-2003, 05:57 AM
Bob
Old 07-11-2003, 10:11 AM
Narflex's Avatar
Sage
Go to Setup->Sources and then do Autotune. Then the channel up/down will work. Initially there's no channels defined, so there's nothing to go up/down to.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 07-11-2003, 05:46 PM
Thanks Jeff!
