Old 08-03-2006, 09:35 AM
MrApollinax's Avatar
MrApollinax MrApollinax is offline
Send a message via ICQ to MrApollinax Send a message via AIM to MrApollinax
XP and SageTV Service question...
This may be a stupid question but does the SageTV service startup when a user logs into their user account or does it start up once the login screen appears?
SageTV Server: Windows XP Pro SP2, 3 GHz DC processor, 2 GB RAM, 256MB GeForce 6800, Plextor ConvertX PX-TV402U, Hauppauge 150MCE
SageTV Extender: Hauppauge MediaMVP
SageTV: 5.0, Comskip STVi, Standard Interface
Router: Dlink DGL-4300
Using Wireshark to Troubleshoot Network Issues with your SageTV Setup
Old 08-03-2006, 10:34 AM
KrisAcker KrisAcker is offline
Actually, all services are started before the login screen appears. The point of using a service is that it starts when windows starts and that it is independent of the user that logs in on the computer.
Old 08-03-2006, 10:39 AM
That's what i thought but since i will be out of the country and wont be able to login to my server if it resets I wanted to know for sure. Thanks for the info!
Old 08-03-2006, 11:56 AM
ybrew ybrew is offline
Make sure you also enable Service Recovery (not enabled by default). If the service stops, Windows can automatically attempt to restart the service.
I actually went into Services (Control panel, admin tools) and set my sagetv service to attempt restart on 1st and 2nd failure and reboot pc on 3rd failure. Failures are set to reset every 24 hours (a feature you can set as well).
If you don't want to do all that, simply open up SageTV Services and check the Service Recovery Button.
