Old 08-03-2006, 10:27 AM
Stuntman's Avatar
Stuntman Stuntman is offline
Question MVP lockups during Networked PC boot ups!
I have a problem where my MVP's will completely lock up whenever I turn ON one of the PC's in my home network! This happens almost immediately and during the PC's post sequence..
Does anybody have any idea why this would be?
I'm running a 100mb switched network with both wired and wireless MVP's..
I'm using Netgear 10/100 switches...
Thanks!!!!!!!!!!!
Old 08-03-2006, 10:53 AM
MrApollinax's Avatar
MrApollinax MrApollinax is offline
Send a message via ICQ to MrApollinax Send a message via AIM to MrApollinax
Are there any services on these computers that are accessing your SageTV server when they boot up? Are they accessing shared folders on the server?
SageTV Server: Windows XP Pro SP2, 3 GHz DC processor, 2 GB RAM, 256MB GeForce 6800, Plextor ConvertX PX-TV402U, Hauppauge 150MCE
SageTV Extender: Hauppauge MediaMVP
SageTV: 5.0, Comskip STVi, Standard Interface
Router: Dlink DGL-4300
Using Wireshark to Troubleshoot Network Issues with your SageTV Setup
Old 08-03-2006, 11:26 AM
Stuntman's Avatar
No.. the weird part is the MVP's lock up almost IMMEDIATELY upon power on of my PC.. Like I said.. at Post.. Windows hasn't even begun to boot at that point.. almost like it is a network burst or some type of broadcast that bumps the MVP offline.. Sometimes the MVP will stay frozen for 10 seconds or so and then the "Booting" MVP screen comes on and you are back at the beginning menu.. I don't think any of the devices on my PC have even come up at the point the MVP freezes..
I'll try fixing the IP's on all my PC's... is there a way to fix the IP's on the MVP's? Perhaps an IP is getting shared, or some type of DHCP issues are occuring... but it does seem unlikely as the timing is such that I don't think the NICS are online yet... but obviously something is going over that network that the MVP doesn't like.. or perhaps the SageTV Server doesn't like..
