Old 08-26-2006, 08:21 PM
Skybolt's Avatar
Skybolt Skybolt is offline
Recording in Divx?
Is there a way, other then the plextor, to record in Divx or xVid formats? I realize that most, if not all capure cards, are mpg2 hardware endcoding. I am hoping for an unattended software option. Thanks.
-Skybolt
Old 08-26-2006, 08:53 PM
MrApollinax's Avatar
MrApollinax MrApollinax is offline
Send a message via ICQ to MrApollinax Send a message via AIM to MrApollinax
I bought the Plextor wanting t use the DivX option. After about a week of that I went back to the mpeg2 recording in DVD quality. The DivX encoding was only single pass and the space saving was so minimal that it wasn't worth the extra cycles to encode in DivX. There is a plugin that does the encoding on the fly as well but for me if you truly are going to use SageTV as a DVR solution you will be deleting the shows after sometime or keeping very specific shows for later. In that case you can do a thourough job of encoding to save space.
SageTV Server: Windows XP Pro SP2, 3 GHz DC processor, 2 GB RAM, 256MB GeForce 6800, Plextor ConvertX PX-TV402U, Hauppauge 150MCE
SageTV Extender: Hauppauge MediaMVP
SageTV: 5.0, Comskip STVi, Standard Interface
Router: Dlink DGL-4300
Using Wireshark to Troubleshoot Network Issues with your SageTV Setup
Old 08-27-2006, 07:09 AM
Skybolt's Avatar
Originally Posted by MrApollinax
... There is a plugin that does the encoding... but for me if you truly are going to use SageTV as a DVR solution you will be deleting the shows after sometime or keeping very specific shows for later...
Any Idea where the Plug-In might be? I scowered the downloads section and could not locate it.
Wanting to use Divx is not a space concern really(Just a Perk) I use MCE as my primary HTPC in my media room. I have gotten Divx to look much nicer than MPG's when recorded from cable, by using ffDShow. Currently I need to convert them into Divx and it is not really worth the effort. The recordings from SageTv give have given me a little trouble playing them and have crashed MCE a few times.
-Skybolt
Old 08-27-2006, 08:35 AM
blade blade is offline
You might look at this .
Old 08-27-2006, 11:26 AM
Skybolt's Avatar
Ahh - Thank you
