Old 09-18-2006, 11:41 AM
DaFrogBoy DaFrogBoy is offline
Cool Where are all the wired MVPs?
Any realistic guess as to when Sage will be getting more wired MVPs? I sent an email over a month ago to get notified when they would be back in stock. I haven't heard back, and the store still shows out of stock. I was just wondering if there are any plans at all of getting them in?
I've already got two wireless MVPs that I'm using as wired, so I'd prefer to save the $50 / MVP and just get wired ones.
Thanks!!
Old 09-18-2006, 12:00 PM
MrApollinax's Avatar
MrApollinax MrApollinax is offline
Send a message via ICQ to MrApollinax Send a message via AIM to MrApollinax
Available at Amazon through Computer Geeks:
http://www.amazon.com/Hauppauge-Medi...&s=electronics
Then all you would need is another licence. Unless you aren't going to use all 3 concurrently. Froogle brings up a bunch of hits as well:
http://froogle.google.com/froogle?q=...Search+Froogle
SageTV Server: Windows XP Pro SP2, 3 GHz DC processor, 2 GB RAM, 256MB GeForce 6800, Plextor ConvertX PX-TV402U, Hauppauge 150MCE
SageTV Extender: Hauppauge MediaMVP
SageTV: 5.0, Comskip STVi, Standard Interface
Router: Dlink DGL-4300
Using Wireshark to Troubleshoot Network Issues with your SageTV Setup
Old 09-18-2006, 12:16 PM
jbarr's Avatar
jbarr jbarr is offline
I just purchased one from PCAlchemy.com for $89.95. They are currently in stock there:
http://www.pcalchemy.com/product_inf...acturers_id/10
You will have to buy the SageTV license separately which PCAlchemy also sells:
http://www.pcalchemy.com/product_inf...roducts_id=522
-Jim Barr
SageTVTips.com
HTPC: AMD ASUS M2N-E Socket AM2 Motherboard; Athlon 64 3200+ Orleans 2.0GHz; 2GB RAM; eVGA 256MB Geforce 7300LE; 1x40GB IDE HDD (OS), 2xSeagate Barracuda 320GB SATA HDD (Recordings); Antec Overture II Case; Windows XP Pro SP2; SageTV v6.5
STV: SageMC
Video sources: Currently, none. I'm using SageTV for Music, Photos, and Video playback.
Old 09-18-2006, 02:50 PM
jimmyb jimmyb is offline
Bunch on Ebay also
http://search.ebay.com/media-mvp_W0QQfsopZ1
The The AnJ Show Will Cook Weather
Old 09-18-2006, 06:12 PM
MoopZilla's Avatar
MoopZilla MoopZilla is offline
I got mine off of eBay a while ago, and they also have them on geeks.com, like the posts above said.
Server: Antec NSK2400 Case, Intel Core 2 Duo e8500, 2GB DDR2 RAM, XP SP3, Gigabyte Fanless 7600GS PCIe 256MB, Sage v6.4
Tuners: 1 H21-100, 1 H20-600 on HD-PVRs both using Serial port tuning(DirecTV), HDHomerun on Comcast ClearQAM
Storage: Seagate 500GB SATA2, WD 1TB SATA2
Video/Audio: Overlay and Cyberlink video/audio
Clients: 2 STX-HD100 HD Media Extenders, 1 MediaMVP
Old 09-19-2006, 11:31 AM
I was hoping to not have to spend extra ($90 for MVP and $30 for license), but I guess that will have to do. I was just curious what the hold-up was. Is there a new version just around the corner? If so, I'll just wait. I'm just surprised this much time has gone by with it still being on backorder.
Old 09-19-2006, 12:01 PM
blade blade is offline
The client is cheaper at PCalchemy. The MVP + client license is only around $6 more than if you purchased the combo from Sage.
