Old 03-10-2007, 10:09 AM
gwgunter's Avatar
gwgunter gwgunter is offline
EPG server problems; EPG Source Location NO longer exists
Over night someone (thing) pulled a magic trick. All my previously existing guide data is gone. So I think well, I'll just reset my video sources and all will be good. Not the case! When selecting "Cable Or Satellite" and entering my zipcode of (73047) I no longer see anything close to what was previously "ALWAYS" there. My city has disappeared. ZAP2IT has all the correct information and looks fine from the web site.
Most irriating!!! As this was working perfectly before. By the way, I tried a fresh complete uninstall/reinstall. I wouldn't be posting this message if it worked. For kicks I even tried the new RC.
At this second, I'm leaving the Version 6.1.4 installed until someone can shed some light on this issue.
Update: New install on different computer and same result. The "EPG Lineup" for 73047 does not exist.
Old 03-10-2007, 04:09 PM
There may be a problem with the EPG server -- I got an error saying it couldn't connect when I tried changing my lineup.
What STV were you using? Did you get an error message?
Old 03-10-2007, 04:27 PM
gwgunter's Avatar
I'm using the default STV with 3 tuners and no error messages. Just Satellite EPG's only not my local cable company at 73047. This is a very odd problem as I can change to other zip codes around me and I can see there "cable" services.
I'm going to email tribune service (zap2it) and see if they know of anything. I'll post back when I get a response from them. Any other ideas?
Till then I've manually added about 5 of my favorite channels that I record from to keep me covered. Thank goodness for that option...
Thanks. Gary
Old 03-10-2007, 04:40 PM
traker1001 traker1001 is offline
sage servers out?
I am trying to update my sources and sage keeps coming back to tell me it can't contact the sagetv servers, Anyone know if sage is having server problems or do I need to hunt down a problem on my end?
* merged *
Old 03-10-2007, 04:45 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
Problem fixed.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 03-10-2007, 05:20 PM
OH I see now, I wish people would pm me or something when they move or remove my post, I was starting to question my sanity!!!!
Anyways thank you for fixing the problem, I wasnt sure if it was my side or sage's.
Old 03-10-2007, 05:42 PM
If it had been deleted, you probably would have received a PM. For minor things, it is a waste of my time since I've found that most people never read them. If you can't find your post, you can look at your profile to find a list of all your posts.
Old 03-10-2007, 07:47 PM
gwgunter's Avatar
Originally Posted by Narflex View Post
Problem fixed.
I think this issue is different than that of the original post. To be clear, my "EPG Lineup:" used to say "Hinton CATV - Cable" and/or "Hinton CATV - Digital". These line-ups are now gone. Is this strictly a ZAP2IT issue?? Their web site still shows all my info correctly..
Thanks for your replies!
Old 03-10-2007, 08:12 PM
It is possible that it is a different issue -- see this FAQ for info on how to report EPG problems to SageTV.
I thought it was the same problem because when I tried it earlier, I got no response at all for any zip code. After that problem was fixed, your zip code's info showed up... but I guess I didn't know what entries were missing.
Old 03-10-2007, 09:13 PM
gwgunter's Avatar
I appreciate your repies.
So you saw my zip code info?!? That is more than I'm getting. I'm missing every single channel because it is not in the EPG Lineup only the large satellite carriers are listed.
Sometime a picture helps... I attached some screen shots. The "sourcedetail.jpg" shows what is still listed as my EPG (Notice the "HINTON CATV-HINTON" but in the "EPGLineup.jpg" that information is nowhere to be found today.
Again thanks for sticking with me and replying... I greatly appreciate ANY assistance.
UPDATE: I attempted to use the XMLTV plugins and created an account on the zap2it labs site. The Line up wizard pictured in zap2itpic2.jpg pretty much proves my problem... I'll continue to talk to zap2it for correction.
Old 03-11-2007, 08:16 AM
comedian999 comedian999 is offline
I am having a similar problem. My EPG blanked out yesterday, and was unable to connect when I tried to do a manual reconnect.
As of about the time Narflex posted that the issue was fixed, I was able to connect and refresh my channel list, but as of just now, about 2/3 of my channels are still showing no programming data.
I'll send an email to report the issue to you guys, but I figured I'd post in cast you were still monitoring this issue.
UPDATE: Since everyone else is posting their zip code; mine's 02453. Hey; if it helps grease the skids on a fix...
Thanks.
Last edited by comedian999; 03-11-2007 at 09:19 AM. Reason: Additional Information
Old 03-11-2007, 08:27 AM
walter scott walter scott is offline
suddenly, im also having a problem, i cant get the epg to update at all. tried the add/remove channel trick, tried reboot restart. i know the internet connection is good. last updated on Friday. im in zip code 70809. anyone else having a problem?
Old 03-11-2007, 09:17 AM
OttoNP OttoNP is offline
same issue here in 48071, but EPG update time has read 0 min since my install last night...it appears to be trying to update about every couple hours or so...
Old 03-11-2007, 09:31 AM
exactly what i see going on. is it related to the DST issue, or just a coincidence?
Old 03-11-2007, 09:46 AM
NEOSG NEOSG is offline
Same here. added a couple of channels this morning and their guide data is blank. Forced update via webserver did not help
zip 14051
EPG grabs guide data for Dish and OTA
Old 03-11-2007, 09:56 AM
zip 14051
can you actually complete the update, or does it just state "next update in 0 mins?"
Old 03-11-2007, 10:07 AM
Says forcing update for each enoder
then home page says
Last EPG Update: Mar 11, 2007 11:57:04 AM
Next EPG Update In: 0.00hrs
Old 03-11-2007, 10:08 AM
then home page says
Also, now it says no data rather than being blank
Old 03-11-2007, 10:11 AM
then home page says
This issue is occurring on my box as well.
Old 03-11-2007, 10:19 AM
what is really weird is that i have a friend across town, same cable provider, but different zip code, also running Sage 5. He can update, no problem!
STV Import: Simple Web Radio V1.2 koelec SageTV Customizations 294 02-29-2008 12:53 PM
tvtv alita SageTV Linux 5 01-30-2007 03:46 PM
Help ! Can't 'search' in Studio any more dflachbart SageTV Studio 5 12-08-2006 10:21 AM
Can not connect Sage Client to Server JasonJoel SageTV Beta Test Software 5 08-03-2003 11:33 AM
