Old 05-22-2007, 08:37 PM
LehighBri LehighBri is offline
Is/will Xbox 360 be compatible with SageTV?
I am thinking about getting an Xbox 360 and am interested in if it could be used as a media extender for Sage (similar to how it can be used for Win MCE). Will the Xbox 360 work? If not, are there plans to make the Xbox 360 work with Sage?
Server: Sage 7.1.9 beta; Dell Inspiron 530; Windows 7 Ultimate 32-bit (UAC turned off); 2TB Internal SATA (TV Recordings)
Storage: Synology DiskStation DS411+, RAID 5, 5x 2TB SATA for (DVDs/Music/Other Videos)
Tuners: Ceton InfiniTV w/ Verizon FIOS cablecard (using babgvant's SageDCT plugin)
Clients: 1x STP-HD300; 1x Acer Aspire Revo 3610 (Atom/Ion) w/ SageTV client (Win 7, EVR, FSE on)
Old 05-23-2007, 05:26 AM
Check out this website. Right now the only xbox's you can load linux on had to be made before 2007. All others since have been patched. Not saying that it couldn't happen, but until they get a solid load of linux that works without a problem, then there is no way to even consider the xbox 360 as an extender for Sage.
http://www.free60.org/wiki/Main_Page
Old 05-23-2007, 05:29 AM
I should also point out, the xbox's use as an extender will never be an "out of the box" experience as an extender for Sage as it is for Windows MCE. No way would Microsoft allow that. The only option was as I mentioned above, needing to load linux and then load a placeshifter client.
mce remote conflict with xbox 360 tsitalon1 SageTV Beta Test Software 1 12-01-2006 06:21 PM
Playback Sage recorded TV files on an Xbox 360? popechild Hardware Support 3 11-22-2006 05:00 PM
Sage portable to the XBox 360 in the future? ke6guj SageTV Media Extender 4 08-18-2006 12:48 PM
Xbox 360 Universal Media Remote? Scriber Hardware Support 4 04-22-2006 03:36 PM
Xbox 360 phenixdragon General Discussion 40 05-20-2005 06:25 AM
